Will front tire rub on the fenders when turning
Old Dec 29, 2007 | 06:05 PM
Apiafo's Avatar
Apiafo
Default Will front tire rub on the fenders when turning
I have just recived my 2003 350z and bought 20s, 245 front & 275 rear, i have a Tanabe suspension, the fenders are rolled.
When i turn, the tires are 1/2'' from the fender. is this dangerous to hit the fender if i turn and hit a bump or is the suspension hard enough for it not to happen?
Hey this is probably a beginners question but i am a beginner this is my first car ever, i always had trucks, and i certainly do not want to damage my fenders the first day out, (in 2 or 3 months from now when there is no more snow) do i have to use certain precautions when driving this setup?
Old Dec 29, 2007 | 06:58 PM
rkd350z's Avatar
rkd350z
you are fine but if you want to be safe, give the front tires a little more neg camber and it will be perfect!
as far as the scratching, the fenders don't scratch the tires, upper arm with the bolt scratches tires.. (take out front tire, you will see inside of fender housing)
I know because I'm pretty low too and I just came back from raising my car a bit to eleminate my headache about scraping....(Stance coil)
Old Dec 29, 2007 | 09:09 PM
misterniceguy's Avatar
misterniceguy
I got some 275's up front with +15 offset and it doesn't rub at all.
Old Dec 29, 2007 | 10:45 PM
terrasmak's Avatar
YOu kinda left out what the aspect ratio was on the tires.
Old Dec 30, 2007 | 06:07 AM
Apiafo's Avatar
Apiafo
mysterniceguy, with a droped suspension?
Old Dec 30, 2007 | 10:51 AM
Apiafo's Avatar
Apiafo
fronts are 245-35-20 rears are 275-35-20s
Old Dec 30, 2007 | 11:41 AM
redlude97's Avatar
redlude97
those tires are WAY too big, you want 245/30/20 and 275/30/20, it just looks retarded right now
Old Dec 31, 2007 | 08:04 AM
Apiafo's Avatar
Apiafo
are 245 35 20 probematic? 1/2'' higher side wall than a 30, should i change my fronts to 245 30 20 and if so can i keep my rear 275 35 20s, i wouldn t mind changing 2 tires, 4 would be a bit stiff.
Old Dec 31, 2007 | 08:14 AM
HondaKiller's Avatar
HondaKiller
just leave it, it looks good. You shouldn't run into any rubbing issues except maybe on a hard U-Turn or large bump. Next time you buy tires get the 30 wall.
+1 on the negative camber
Old Dec 31, 2007 | 08:19 AM
The fenders may cut the tires but it looks cool. That’s what matters.
Apiafo's Avatar
Apiafo
What do you mean by +1 negative camber
Old Dec 31, 2007 | 09:33 AM
HondaKiller
it's an adjustment to your front suspension that will move it away from the fender wall slightly.
Old Jan 1, 2008 | 05:04 AM
TeAm PrOSpEc's Avatar
TeAm PrOSpEc
who the h3ll would want to put 20's on a Z anyways!
Old Jan 1, 2008 | 07:08 AM
Apiafo's Avatar
Apiafo
I do, and i did and a lot of alot of people out there.
Its easy to quote your saying, but do you have the ***** to say that every time you actualy see some guys 350z and tell him in his face? Too easy to b1tch behind your screen, or is that the only adreniline you get.
Happy New Year!
Old Jan 1, 2008 | 09:05 AM
ncparamedic's Avatar
ncparamedic
Prodigal Son
Happy New Year!
Easy guys..
Old Jan 1, 2008 | 10:37 AM
misterniceguy
Yup, not a big drop though. 13.5 front and 14 rear I think.
Old Jan 1, 2008 | 11:02 AM
islandsnow's Avatar
islandsnow
Happy New Year!
Actually one japanese tuner Mr. Okayama used 20" rims on his car too and it wasn't detrimental in handling or weight wise. You figure it's only +2, and with the right tire combination, you can make it close to stock diameter. It's not like he put some chrome 22" or something. Anyways Apiafo, don't worry what other people say. There's always someone going to put the hate on anything not standard.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
