Big Brake Kit Picture Thread!!!
Originally Posted by mthreat
Definitely not every turn!
Turn 1, Texas World Speedway CCW... 135mph down to around 75
Two seconds is probably the best case scenario, but I seriously gain all kinds of time with those brakes.
Or, Turn 15, TWS clockwise (other end of the above straightaway), same deal.
Two seconds is probably the best case scenario, but I seriously gain all kinds of time with those brakes. Or, Turn 15, TWS clockwise (other end of the above straightaway), same deal.
Performance Nissan
Performance Nissan
First Setup:
STOPTECH 355mm Slotted ST60 Red
STOPTECH 328mm Slotted ST22 Red
New Setup:
Project Mu Racing Caliper Kit 6 Piston 355mm
Project Mu Racing Caliper Kit 4 Piston 345mm
New Setup:
Great pics everyone!!! For those that can answer this... Think I'll have any problem running the following kit with the following wheels?
StopTech Front & Rear Kit
- 14" (355mm) ST-40 4-Pot Front
- 13" (328mm) ST-22 2-Pot Rear
Wheels: Work Meister S1 3-piece
Front Size & offset: 19x9.5 R Disk +24 offset
Rear Size & offset: 19x11 R Disk +36 offset
Performance Nissan
Performance Nissan
you will need spacers for the front for sure. i have the same wheel upfront and have to run a 5mm spacer.
i'm pretty sure you will need spacers for the rear too - i'm putting mine on this weekend and i have a 11.5 + 22 A disk out back and i'm questioning if it's going to clear.
Originally Posted by Andy@Performance
Offset does not determine caliper clearance, pad type does. You need to find out what pad type you have. If these are Rickdogg's old wheels and looking at the fitment, it was, I doubt this BBK will clear. He had Rotora's and Rotora calipers are smaller than STOPTECH's. You should seriously print out the STOPTECH caliper clearance chart off their site and check yourself.
5mm for the front - i couldnt tell you until i mount the rears, but your rears are different than mine. the easiest way would be to goto the stoptech page and print out their diagram. and take of a rear wheel and measure to see if it will clear
Project MU Racing Caliper BBK
6 Pot Racing Caliper 355 Front
4 Pot Racing Caliper 332 Rear
Work Varianza T1S in Machined Silver Polsihed
19x9.5 +24 R
19x11.0 +22 O
19x9.5 +24 R
19x11.0 +22 O
Performance Nissan
Performance Nissan
Originally Posted by Z1 Performance
actually both offset and pad type can determine brake clearance, because not all wheels have an option of multiple pad heights for a given offset.
I hear ya - it atually has nothing to do with low end or high end. It's something specific wheels have or don't have.
He will definitely need front spacers. I can't say on rears as I've never sold/used that size
