Rear End is Sqeeking
Old Jan 10, 2008 | 01:59 PM
sadclown's Avatar
sadclown
Default Rear End is Sqeeking
Need a little help, the rear is sqeeking when i drive, sounds like it coming from both sides, any idea whats causing this?
Thanks in advance
Old Jan 10, 2008 | 02:58 PM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
How old and how many miles do you have on the car? Mine sqeaked a little before I got coilovers especialy when it was colder.
Old Jan 10, 2008 | 03:10 PM
sadclown's Avatar
sadclown
its a 2005, with 36k miles, i do have Tein w/ EDFC. It hasnt really made any noise until this week, everytime i drive over anything the even looks like a bump the back will sqeek.
O, my Z is a vert
Old Jan 10, 2008 | 03:28 PM
WD40 fixes everything!
Old Jan 10, 2008 | 04:26 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Lightbulb You...
got milk there son...
Old Jan 10, 2008 | 06:25 PM
terrasmak's Avatar
Please no , it will actually make it worse. WD is not a lube , and does not say it is anywhere on the can.
Old Jan 10, 2008 | 09:36 PM
r26's Avatar
r26
ky is a lube
r26's Avatar
r26
Thanks in advance
do you have sway bars?
Old Jan 11, 2008 | 04:23 AM
reptile718's Avatar
reptile718
My guess is either your end links are starting to go bad or you have the axle click issue which your dealer can take care of for you. Either way its not serious but the noise will increase over time. Is the noise only heard when you stop and go or over bumps and turns. Bumps and turns = end links (cheap fix, about 30-40 per side + install) Stop and go = axle click (TSB report out on this, the dealer will know what to do) Cost about $130-160 total. I have had both these issues fixed before no problem and they have not come back. Good luck!
Old Jan 14, 2008 | 09:10 AM
sadclown's Avatar
sadclown
thanks for all the help guys, gonna have to bring it in one day.
The squeek sound is noticeable when the car is turning and over bumps
Old Jan 14, 2008 | 09:12 AM
fast kiwi's Avatar
fast kiwi
strnagly enough.. I have an 05 and mine "squeeked" also. The dealership could never fix it.. It went away after i installed my springs and sways..
Old Jan 14, 2008 | 09:16 AM
reptile718's Avatar
reptile718
Its your end links then. They attach to the end of each rear sway bar. Cost about $30 a piece from the dealer and are super simple to install. Two bolts all done!
pr_350z
Oct 1, 2015 05:03 PM
