Tanabe Sustec Pro Five Question
Old Jan 11, 2008 | 07:25 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Default Tanabe Sustec Pro Five Question
I'm thinking about getting this as well as the TEAS. My car currently has only Swift Linear springs with about 7k miles on them. When I swap in the coilovers should I use the Swift springs or the Tanabe springs?
What benefit would I have with the Swift, I know they are much higher quality then most other springs and that Zeal even uses them on their coilovers, should I be doing the same?
Street application mainly.
Old Jan 11, 2008 | 11:03 PM
SilverJDMCoupe's Avatar
SilverJDMCoupe
Keep the Tanabe's.
Old Jan 12, 2008 | 06:44 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Why?
Old Jan 12, 2008 | 10:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
? if you swap in coilovers you would be replacing your existing springs...
Old Jan 12, 2008 | 07:13 PM
Gsedan35's Avatar
Gsedan35
Zeal uses swift, Ohlins coming out of Japan use Eibach. http://www.carrozzeriajapan.co.jp/oh...ing_banner.jpg
Without getting into weather or not Swifts claims about what makes their springs better then other companies products is or isn't legit, two things come to mind. And I'm assuming your not talking about running the swift lowering springs you have now, but Swift coilover replacement springs.
1. Less weight
2. Kicking Tababe's progressive springs in the rear* to the curb.
*IIRC, in the rear Tanabe uses a 5" outside diameter spring on their coilovers, not a 2.5"ID spring. Swift doesn't offer a 5" OD spring that I'm aware of. Eibach does, it's called ESS.
Old Jan 12, 2008 | 07:25 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
thanks for the info
Old Jan 12, 2008 | 07:44 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by dspiel
thanks for the info
Your welcome, IMO the whole value of replacing the Tanabe springs is totally your judgement call, kind of thing only you can place a value on. I won't run a progressive spring on any car of mine what has sporting intent, that's my stand in that area.
Old Jan 13, 2008 | 05:39 PM
deisel's Avatar
deisel
get the pro 7s. love my tanabes handles nice and smooth. very high quality if u have questions give Reggie a call at tanabe usa
issyz
Jul 2, 2017 03:04 PM
