Rear Camber
Old Feb 5, 2008 | 01:38 PM
WyattH's Avatar
WyattH
I couldn't find the SPC for $150 at AJUSA - Link please? That is a good price.
Old Feb 6, 2008 | 08:36 PM
batmanesaul's Avatar
batmanesaul
me too i need them bad lol
Old Feb 6, 2008 | 08:46 PM
redlude97's Avatar
redlude97
you have to look under eibach, the eibach is a reboxed SPC kit. http://www.ajusa.com/details/index/2....50L%20V6%20FI
Comes with both the camber arms and toe bolts even though it only says camber arm
Old Feb 10, 2008 | 04:25 PM
hiz-n-herz's Avatar
hiz-n-herz
Originally Posted by rkd350z
I wanted PS2s but it has inside/outside as well as rotation direction.. so out of my option even though it is very nice tire..
FYI... PS2's are not directional - they don't have a rotation direction. The original Pilot Sports were, but not the PS2's
Old Feb 11, 2008 | 02:31 PM
rkd350z's Avatar
rkd350z
they donn't???
Old Feb 11, 2008 | 05:54 PM
Nevaland90's Avatar
Nevaland90
Originally Posted by redlude97
what is your toe?
-0.4 F
0 R
all my spec.
Old Feb 12, 2008 | 07:27 PM
TNguyen7's Avatar
TNguyen7
thanks a lot! just ordered and going to get my camber straightened up!
Old Feb 13, 2008 | 01:55 AM
Sensi09's Avatar
Sensi09
Works Concepts
It's best to have your camber in check along with the ability to adjust it, but a lot of times one must weigh the cost of tires versus a camber kit.
I figure the camber kit along with install and alignment is about $400-500 all together. Rear tires depending on your size, will roughly be the same price. Again if you got 25K miles out of your rear tires and are still going, your camber really isn't that bad and is likely within spec.
Old Feb 13, 2008 | 05:32 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
SPL ownz all camber kits. The best quality and the product is actually tested on the track before it was ever released. The parts are Beefy too.
Old Feb 13, 2008 | 07:40 AM
TNguyen7's Avatar
TNguyen7
valid point but i guess i'm doing this more of a trial and error just to see if there is a difference.
Old Feb 13, 2008 | 09:47 AM
bluezup's Avatar
bluezup
if i can remember right, i heard somewhere before that with the spc camber kit, it should only be install if our cars are drop on coils or spring+shock, and not spring alone. can anyone confirm this? im not saying its true or not, i just heard and remember reading it somewhere in this forum a few days ago.
Old Feb 13, 2008 | 10:21 AM
redlude97's Avatar
redlude97
completely false
Old Feb 13, 2008 | 10:22 AM
redlude97's Avatar
redlude97
Or you can do it yourself for ~$200 total including alignment
Old Feb 13, 2008 | 10:48 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yep, I just installed the SPL ones on a guys car this last weekend. Very nice product. Wish I was at my house though with my tools it would have made life easier. But basically all it takes is removing two bolts one on each end, but you also need to remove the sway bar mounts where it attachs to the frame of the car so you can remove the factory bolt. Otherwise, it took less than 2 hrs total with a bunch of goofing off.
Old Feb 13, 2008 | 10:51 AM
redlude97's Avatar
redlude97
Did you just install the SPL camber arms?
Old Feb 13, 2008 | 10:54 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yes.
Old Feb 13, 2008 | 10:58 AM
redlude97's Avatar
redlude97
Yes.
How does he plan on getting his toe in spec
Old Feb 13, 2008 | 11:20 AM
  #38
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I don't have the instructions in front of me, but the SPL camber arms have adjustments for Camber and Toe. There was instructions on how to adjust both but I didn't read that part throughly since I was just worried about getting it installed he would take it to the alignment shop.
Old Feb 13, 2008 | 11:25 AM
  #39
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
http://www.splparts.com/main4/parts/...ilink.htm#Rear camber arms
SPL camber arms. The bolts adjust the toe they send with them.
Old Feb 13, 2008 | 01:38 PM
  #40
redlude97's Avatar
redlude97
Yes, the SPC toe bolts. Where did you install them, on the end of the camber arm or the spring bucket? and did you elongate the hole?
