Suspension install problem
Old Feb 3, 2008 | 09:46 PM
Roguewolf's Avatar
Roguewolf
Default Suspension install problem
Hey guys,
So i got s-techs for my G and i installed and finished the back but im having some problems with the front. i swapped the springs on the shocks and i put them back but im having difficulties putting back the bolts in the A-arms. http://pics.montypics.com/Gcoupe35/2...ll_how_to5.jpg the top curvy thing. One of them does it with some pushing and shoving. but the other one will not go in for the life of me.. so now the car is sitting outside on stands and a jack.. Please any help/ideas/pics on what to do to get the A-arm in. Any help will be greatly appreciated.
Thanks,
-Rogue
Old Feb 3, 2008 | 09:49 PM
gdup35sedan's Avatar
gdup35sedan
link to the picture didnt work
repost it and i'll see if i can help ya
-GP-
Old Feb 3, 2008 | 09:50 PM
Roguewolf's Avatar
Roguewolf
Edited * http://pics.montypics.com/Gcoupe35/2...ll_how_to5.jpg * in case
Old Feb 3, 2008 | 09:53 PM
gdup35sedan
i dont understand what you're trying to figure out... the picture shows no illustration of a problem.
-GP-
Old Feb 3, 2008 | 10:02 PM
Roguewolf's Avatar
Roguewolf
i just ran downstairs and took shitty pics... here
it seems like the springs are in the way of the bolt. that bolt is quite long as well..
Old Feb 3, 2008 | 10:05 PM
gdup35sedan
unbolt the 3 12mm bolts on top that hold the strut in place, then you can move the whole assembly up or down until the a-arm bolt fits in there.
-GP-
Old Feb 3, 2008 | 10:07 PM
Roguewolf's Avatar
Roguewolf
would i have to unbolt the sway bar, cuz i have them unbolted now and it still wont move up or down.
Old Feb 3, 2008 | 10:08 PM
gdup35sedan
yes, unbolt the sway bar and take the end-link out of the hole so it can move.
-GP-
Roguewolf's Avatar
Roguewolf
btw are my spring son the right way cuz even tho i put them the same exact way as the stock ones the writting is upside down.. please don't tell me i got em on wrong...
Old Feb 3, 2008 | 10:10 PM
Roguewolf's Avatar
Roguewolf
so i gotta basically unbolt the whole shock/spring and put on the A-arm and them put the shock/spring back?
Old Feb 3, 2008 | 10:12 PM
gdup35sedan
lol, the brown rubber stuck to the spring is supposed to be on the bottom so its the metal spring isnt just sitting on the metal on the strut, it prevents noise. so if you get some squeking or metal rubbing noise... you know why.
-GP-
Old Feb 3, 2008 | 10:13 PM
Roguewolf's Avatar
Roguewolf
so it's upside down..?
gdup35sedan
you shouldnt need to unbolt the the strut from the lower control arm, once the sway bar is un-bolted, and you have the top bolts off, you should be able to push it down or wiggle it around enough to get the a-arm bolt in there.
-GP-
Roguewolf's Avatar
Roguewolf
but i kept the oem rubber boots
Old Feb 3, 2008 | 10:15 PM
gdup35sedan
which are mounted on the bottom side of the spring... not the top. but you put them on the top?
-GP-
Old Feb 3, 2008 | 10:16 PM
Roguewolf's Avatar
Roguewolf
nah i left them at the bottom.
Old Feb 3, 2008 | 10:17 PM
gdup35sedan
then you should be fine. Get that A-arm bolt in there slap the wheels on and enjoy your drop!
-GP-
Old Feb 3, 2008 | 10:18 PM
Roguewolf's Avatar
Roguewolf
yea i'll do it in 5 hours or so thx for the tips
gdup35sedan
no problem.
-GP-
Old Feb 4, 2008 | 05:45 AM
RedBullRR's Avatar
RedBullRR
Dam you didnt have to take that apart in order to put put springs on. Not sure why you did that... Would have been a **** load easier if you un-bolted from here.
This is what I did, and I finished this job in about an hour or so. You have to use some kind of fork to create pressure in order to completely unbolt.
