how low can you go with coilovers
Mine scrapes on most speed bumps, even when I drive at a angle so that each wheel passes over the speed bump seperately. So how how many speed bumps are you wanting to scrape on a daily basis???
G35 coupes ride .5" on average higher then the 350Z. Any info you get that is 350Z based needs to have that .5" added in.
The lowest drops will occur with coilover setups that run the rear springs on the rear dampners (called "true coilover). Something tell's me you should run a search on Stance coilovers and spend the tire required to get your own answer. We have several Z owners here that are dropped with the Stance setup for no other reason then to get really low. Lower then many of us would ever consider(looks or function wise). Though costly, Zeal does offer a true coilover setup, dampning would be light years ahead of the Stance setup, price is too however.
350Z_Al
Oct 29, 2020 07:44 PM
