back to specs with eibach sportlines
Old Feb 10, 2008 | 12:58 AM
ev0k1ll3r's Avatar
ev0k1ll3r
Default back to specs with eibach sportlines
as the title states, i am just wondering if anyone has had any luck with getting the front alignment back to decent specs with the eibach sportline springs with out a camber kit. after searching a bit, i hear that in some cases they may settle to a 2" drop. i am torn between these or the pro kit springs. i am just hoping that i will be okay without the front camber kit with sportlines cuz i really want more than a 1" drop. please help me... at least i tried searching
edit: 07 with 18/19 gt wheels oem tires
Old Feb 10, 2008 | 06:23 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there is no way you will ever get the front back to spec without a camber kit on a spring that lowers the car that much. Even with a prokit, the chances of it still being within stock specs up front without aftermarket arms are slim
as for sportlines + stock struts...might look cool, but if you want the car that low, and you actually want to retain good handling, springs are not the right way to do it
Old Feb 10, 2008 | 06:15 PM
black06z's Avatar
black06z
You'll need the front and rear camber kits.
Old Feb 10, 2008 | 09:09 PM
350ZPK's Avatar
350ZPK
if your going that low...go coilovers.
If you want a nice drop and not slammed ..go with the GF210..enuff said!
Old Feb 10, 2008 | 09:29 PM
ev0k1ll3r's Avatar
ev0k1ll3r
thanks for the replies guys! yeah after thinking about it and a little more searching i decided the slammed z will just have to wait til i can get some coilovers. for now im pretty sure im going for the gf210s. i like that drop. will my front alignment be reasonable with those springs? (by reasonable i mean my tires wont be gone in a couple thousand miles but at the same time good handling) btw i am already for sure getting the spc rear alignment kit.
Old Feb 10, 2008 | 09:37 PM
Get_Zwole's Avatar
Get_Zwole
some people say no but i think 1 inch you will be able to come close to stock specs if anything they will prob wear about the same time your rears do so its more practical that way anyways haha. Im getting my eibach pros on wednesday or thursday and i only ordered the rear camber for now couldnt see spending the money on the front till i know im gonna need it.
Old Feb 11, 2008 | 05:01 AM
Z1 Performance
Former Sponsor
no one can tell you till you install them and put the car on the alignment rack
Old Feb 11, 2008 | 06:34 AM
ev0k1ll3r's Avatar
ev0k1ll3r
sounds good i will just have to make sure to set some money aside for "just in case" lol!
Old Feb 11, 2008 | 06:55 AM
Q45tech's Avatar
Q45tech
Don't confuse static alignment with what's important [driving 60 mph real alignment] just because you can use some aftermarket kit [gimmick] to get the sitting still alignment back into range.
The lowering changes the camber curve SHAPE which can only be TRUELY FIXED by changing the suspension attachment point on the chassis.
Just like lowering changes the angle between steering rack and tie rod ends.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
