install problem: rear strut bolt/nut
Old Feb 21, 2008 | 04:54 PM
creationv2's Avatar
creationv2
Default install problem: rear strut bolt/nut
so i was installing some coilovers (i got used) today on the z and when i got to the rear struts i discovered that the nuts were part of the OEM strut, so i couldnt install the new struts because there was not nut to secure the bolt.
is there supposed to be a nut that comes with the coilover system to secure that bolt? if nto where can i get a but that fits the bolt?
Old Feb 22, 2008 | 11:17 AM
dklau33's Avatar
dklau33
You're talking about the bottom of the rear shocks where the nut is already intregrated onto the shock right? Which coilover system did you get? The seller probably didn't give you the correct nut that caem with the coilovers. You can probably just bring the oem bolt to a hardware store and find the correct nut that you need.
Old Feb 22, 2008 | 04:32 PM
creationv2's Avatar
creationv2
i tired to find a nut, but to no avail....would it be safe to just buy a whole new nut and bolt?
Old Feb 22, 2008 | 08:12 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
when i installed my JIC's, the stock bolt was too short. there would only be two or three threads that would engage on the nut. this of course is unacceptable. you could buy a longer bolt, but make sure you get either grade 8 or above nut/bolt (if using SAE) or 10.9 (head stud, metric) bolts along with a type C locking nut (which matches the hardness of the 10.9 bolt). don't buy any grade less.
Old Feb 22, 2008 | 08:24 PM
Endless Shock's Avatar
Endless Shock
I totally agree with your steel grades... I wouldnt go any lower either...
OP: The OEM bolts for the front are longer than the rears... They are special order and the cost a little bit more... This might be an option...
Old Feb 23, 2008 | 09:17 AM
creationv2's Avatar
creationv2
oh i see, thanks to the last two responses...i was gonna ask about the grade as well, so thanks. and if the front bolt has a separate nut, i think ill go with that.
Old Feb 23, 2008 | 11:41 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
the OEM front bolt has a nut. the part number for the bolt is 56127N and the nut is 54060B per courtesynissanparts.com.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
