Tein or HKS coilovers
Hey, anybody know if the HKS hypermax II coilovers have the dampening adjustment on top or on the bottom. That is, do I have to get to the top of the unit (a pain for the rear suspension) to change the dampening rate? Then we would not really need the Tein remote thing. I think DMC makes coilovers like this - but I hear they're not so good.
Wow, this thread was revived from the dead!
Originally posted by ___DJK___
The fronts are adjusted on top (you can access when you pop your hood) and the rears are adjusted on bottom (if you have open spokes you can reach through and adjust)
Ah ha! I knew there was a quality coilover out there that has a relatively easy manual dampening adjustment.
Now, to anybody that has HKS hypermax II: Is the pillow-ball mount "noisy" like the old Tein Flex??
I have not read a review of the newer model Tein's. I heard from Jacky at Tein that a hard rubber upper mount is available but I think this only works for the basic and type-cs.
I bet, that for the same price the HKS hypermax is a better quality and better handling coilover than the Tein. Remember that pesky EDC system takes hours to install (read hundreds of $) and besides it seems like everybody has one. Can anybody back this up?
The front dampers make absolutely no noise whatsoever. The rear dampers make a bit of a sqeaking noise when you go over bumps, but it's not that annoying. I'm guessing it will go away after a bit of use. But there's definitely no "clunking" noise from the springs that you get with some other coilover suspension systems.
the hks makes no noise at all and is a great setup...i have the ls+ and i am very happy. the ride is not harsh, its easy to adjust both front and rear dampners, and the performance is outstanding
