Wht else would I need
Old Mar 6, 2008 | 08:42 PM
_NIZMO_'s Avatar
_NIZMO_
Default Wht else would I need
If I end up buying a "shock and spring setup" or coilovers, wht else will I need....camber kit etc....which one etc...
Old Mar 6, 2008 | 09:01 PM
_NIZMO_'s Avatar
_NIZMO_
search noob
Old Mar 6, 2008 | 09:24 PM
tribal_visionz's Avatar
tribal_visionz
alignment, search noob!
Old Mar 10, 2008 | 11:05 AM
_NIZMO_'s Avatar
_NIZMO_
I know I would need an alignment, but what else is "needed" as far as parts go....camber kits etc.....
Old Mar 10, 2008 | 11:46 AM
nkohler's Avatar
nkohler
front camber cannot be adjusted on the stock suspension. so if you go any lower than 3/4 to 1 inch you will need a front camber kit to bring the camber back into spec.
rear camber can slightly be adjusted, but not enough to matter, so a rear camber and toe bolt kit would be needed for anything over an inch as well to bring it back into spec.
front kits run anywhere from $300-500 or so
rear kits run around $150-200 give or take.
visit any reputable vendor here that sells suspension and they will have a kit or two for you to look at.
Old Mar 10, 2008 | 12:58 PM
_NIZMO_'s Avatar
_NIZMO_
so pretty much all I would need is acamber kit for my front and rear, and an alignment after that?
how hard is it to install the camber kits
Old Mar 10, 2008 | 02:30 PM
HyperV6's Avatar
HyperV6
F/R Sway bars and links.
Old Mar 10, 2008 | 02:59 PM
_NIZMO_'s Avatar
_NIZMO_
that isn't needed though
Old Mar 10, 2008 | 04:47 PM
Gsedan35's Avatar
Gsedan35
Once you understand what oem parts come off and how, the new parts go on in reverse order. The front kit is easier to install with the shock/ spring or coilover assembly off the car. Installing elongated toe cam bolts to get greater rear toe adjustment will be the most difficult thing since some grinding with a dremel is required (a how to thread does exist on this board).
RavSpec
Aug 20, 2020 07:01 AM
AspecWheels
Apr 16, 2013 08:54 AM
tashi
Drift
Nov 27, 2005 07:10 PM
