>1" F, 1.2"R springs?
Old Mar 8, 2008 | 05:04 PM
_Fayte_'s Avatar
_Fayte_
Default >1" F, 1.2"R springs?
Is there a spring that drops @ 0.75" or less in the front, and 1.2" or more in the rear? Im looking for a drop but don't want that much in the front.
Old Mar 8, 2008 | 06:19 PM
zMOSESz's Avatar
zMOSESz
you really think that would look right. Tanabe is 1.2 rear, 1.0 front.
Old Mar 8, 2008 | 10:59 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
Tanabe GF210 springs are about as close as you will get. 1" drop in the front and 1.2" drop in the rear.
Here's how it looks
If you are interested in these springs PM me and I can get you more info.
-Dan
Old Mar 9, 2008 | 09:01 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Tanabe Gf!
Old Mar 10, 2008 | 05:29 PM
Gsedan35's Avatar
Gsedan35
Tein 350Z S-tech with modifed upper spring seats to drop the rear 1.2".
Better spring rates then GF210 and the exact drop you want.
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Not much stiffer vs oem, IMO Eibach prokit is a better choice because of that springs higher spring rates which should help keep you off the bumpstops more often.
Oem spring rates
350Z 2003/2004
Front:314 Rear:342
350Z 2004.5 to 2008
Front:314 Rear:427
Old Mar 10, 2008 | 05:49 PM
zonic03's Avatar
zonic03
Here's how it looks
-Dan
Looks GOOD!!! Im getting a 1.2R and !.2 F drop. I kinda regret it now.What
Old Mar 10, 2008 | 05:50 PM
zonic03's Avatar
zonic03
Here's how it looks
-Dan
Looks GOOD!!! Im getting a 1.2R and 1.2 F drop. I kinda regret it now.What you think of 1.2 F&R?
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
