Rear camber arms, Very loud anoying clunking sound
Old Mar 11, 2008 | 08:09 PM
Rowlett's Avatar
Rowlett
Default Rear camber arms, Very loud anoying clunking sound
I did no search here....
I got no answers from another forum maybe ill get them here...IDK
Just a thought, i'v replaced my rear camber arms with some new adjustable ones, after taking down sway bar, i figured i hadnt tightend it up enough due to some loud anoying clunking sqeaking sounds...so i wnt back and checked for any looseness no luck bushings are all lubed up and etc. Then i m starting to think that its maybe no bushings in the new camber set? Any one have this problem?
-----------------You guess it--------------------
Not Stillen camber kit, Top Speed...!
Old Mar 11, 2008 | 08:10 PM
Rowlett's Avatar
Rowlett
haha... ---PIC=FAIL
Old Mar 11, 2008 | 08:13 PM
Rowlett's Avatar
Rowlett
Old Mar 16, 2008 | 07:38 PM
Rowlett's Avatar
Rowlett
Bump Please...
Old Mar 17, 2008 | 05:03 PM
JZ39's Avatar
JZ39
Most likely you need new sway bar end links.
Does it make the sound when you are going up a driveway etc. where one wheel goes up or down before the other?
If so, invest in some new end links.
Old Apr 3, 2008 | 05:08 AM
Rowlett's Avatar
Rowlett
mmm, Yeah kinda dose...
Ill invest...
Any other opinions?
Old Apr 3, 2008 | 07:57 AM
thinking's Avatar
thinking
Remove rear sway and endlinks and see if noise goes away.
Old Apr 3, 2008 | 08:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if the noise wasn't there before you installed the arms, and it is there after you installed the arms...then it's not your endlinks
Old Apr 4, 2008 | 11:29 AM
SMART Auto Perf's Avatar
SMART Auto Perf
There are factory TQ settings for each suspension nut/bolt combo. For proper suspension function, you'll want to check all your TQ settings.
Obadabot
Jun 18, 2023 11:31 PM
