Can you say Aragosta?
Old Mar 11, 2008 | 09:35 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default Can you say Aragosta?
I was lucky enough to pick up a barely used set of Aragosta standard suspension (It only has 700miles on it). I'll write up a review once I receive it and install it. Meanwhile, enjoy the pics!
Attached Thumbnails Can you say Aragosta?-rccms645-img600x450-1204688730img_2016-1-.jpg   Can you say Aragosta?-rccms645-img600x450-1204688764img_2019-1-.jpg
Old Mar 12, 2008 | 05:15 AM
OH6 G35's Avatar
OH6 G35
Nice set-up...looking forward to your review!
Old Mar 12, 2008 | 09:46 AM
Advent7's Avatar
Advent7
o snap! Argosta coilovers are pretty expensive from what I remember. Anyways enjoy the new coilovers I can't wait to order a set or my Z.
Old Mar 12, 2008 | 09:48 AM
MethodRN's Avatar
MethodRN
For Sale
WOW! Impressive. Good find!
Old Mar 12, 2008 | 10:02 AM
Motormouth's Avatar
Motormouth
true rear coilovers and additional springs in the rear right?
Old Mar 12, 2008 | 11:34 AM
Sensi09's Avatar
Sensi09
Works Concepts
Wow, Aragostas. Are these still made or did they ever make production?
I remember reading about them years ago. They were supposed to be at the high end for the Z market, but didn't hear much about them after that.
Old Mar 12, 2008 | 11:37 AM
Motormouth's Avatar
Motormouth
because they are like 8k a set or something is probably why.
you can still get them from Bulletproof and Z-1 I think.
Old Mar 12, 2008 | 01:15 PM
gsazabi's Avatar
gsazabi
Omg
Old Mar 12, 2008 | 06:03 PM
drift freaq's Avatar
drift freaq
You can order Aragosta's from splparts.com they are in Texas.
Old Mar 12, 2008 | 07:45 PM
Sensi09's Avatar
Sensi09
Works Concepts
The pricing isn't too bad. Splparts lists them at $2700 for the standard version and $2900 for custom valved. Similar in pricing to Zeals or Ohlins.
But the 3-ways are $5099
Old Mar 12, 2008 | 08:31 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Yeah, they are about in line with Zeals and Ohlins.
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Yup, what you see is what you get!
Old Mar 12, 2008 | 08:39 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I actually got to drive a Z with Aragosta suspension, and I was quite impressed.. Hence the reason for getting it for myself. I currently have Tein Flex.. Not impressed and so noisy...
Old Mar 12, 2008 | 09:01 PM
daytona350z's Avatar
daytona350z
curious as to what spring rates they run
Old Mar 13, 2008 | 08:56 AM
Gsedan35's Avatar
Gsedan35
http://www.tpl.co.jp/Aragosta/standard.aspx
616/336 and 112
If you do the math, those two rear springs equal a 605lbs spring run only in the oem rear location.
I am positive that the 336lbs spring is the progressive oem type spring and the 112lbs spring is on the rear dampner. I say this because of the wire diameter's of each spring that you can see in the pictures. If I'm wrong and it's the other way around, then the rear combined spring rate is equal to a 910lbs spring run in the oem location.
Two model's are listed on Topline's web site, both setup's have the same spring rates
Standard (part# 3AAA.ND.B1.000)
Comfort (part# 3AAA.ND.A1.R00)
SPL's web site lists the Standard model $2699, custom valved $2899 and a 3 way adjustable setup for $5099
http://www.splparts.com/main4/parts/...rs/default.htm
Go to the bottom of the page
They also warn you, "Built on order and imported from Japan. Special order 3-5 weeks"
FYI Ohlins does offer their PCV and DFV coilover for the Z
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2155
Old Mar 13, 2008 | 09:54 AM
Gsedan35's Avatar
Gsedan35
If you need them serviced or revalved in the U.S., how many places are authorized to do the work in this country?
350zrn35
Nov 2, 2014 06:53 PM
sfarrah
Nov 18, 2008 07:08 AM
z461
Jan 28, 2003 08:51 AM
