Brake pedal makes noise after brake pad install
Old Mar 14, 2008 | 11:00 AM
brandonhh's Avatar
brandonhh
Default Brake pedal makes noise after brake pad install
I replaced my front brake pads yesterday, and since have noticed that the brake pedal now makes a noise when pressed/released. It sounds like air, kind of like a foot-air pump that you would use on a bicycle tire. Any ideas on what would be causing this? Or how to fix it? Thanks in advance.
Old Mar 14, 2008 | 11:54 AM
HondaKiller's Avatar
HondaKiller
did you remove the caliper? Refill fluid?
Either way, bleed your brakes. you can probably find a "how to" somewhere on the site. Basically, push hold brake, turn crew - squirt/tighten screw, release brake. Repeat that 5-6 times and you should be tightened up.
seagrasser
Oct 11, 2015 03:27 PM
