Camber question
Old Mar 15, 2008 | 04:38 PM
powerofz's Avatar
powerofz
Default Camber question
Does the 350Z come stock with adjustable rear camber arms? befor i go out and buy some...
Old Mar 15, 2008 | 04:41 PM
haeshik's Avatar
haeshik
fail
Old Mar 16, 2008 | 05:41 PM
powerofz's Avatar
powerofz
take that as a no?
Old Mar 16, 2008 | 05:46 PM
powerofz's Avatar
powerofz
the s2000 come stock with adjustable rear camber arms... didnt know if the Z's would
Old Mar 16, 2008 | 05:47 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Camber and toe is adjustable, but the range is limited. If you're lowered more than an inch you'll need to install a rear camber/toe kit.
Old Mar 16, 2008 | 05:53 PM
redmike_02's Avatar
redmike_02
Ummm........I'm only lowered 0.6 inches and my car is beyond factory specs. It is a good investment if you want to get good tire wear.
Old Mar 16, 2008 | 06:17 PM
dutchboy350Z
Finally some go
Umm what's your point? FYI ... dumping money into a car is never considered an "investment"
Stock camber can be adjusted + or _ .5 degrees. Lowering your car only a 1/2 inch should not require a camber/toe kit.
Old Mar 17, 2008 | 12:19 AM
redlude97's Avatar
redlude97
That is if you only wanted to barely get back into the OEM spec range. To set the camber to the nominal settings, a camber/toe kit is almost always going to be needed.
Old Mar 17, 2008 | 05:42 AM
Q45tech's Avatar
Q45tech
As the miles build up the rear subframe mounting tabs bend and rubber bushings wear such that camber increases negatively, so what works on brand new won't last as you approach warranty termination.
Same thing happens to front with the shock tower wanting to deflect inward from continuous pressure...............a tiny bit here and there adds up to increases in negative camber.
1/8" is ~~ 1 degree camber how much slop are in your bushings
Old Mar 17, 2008 | 01:45 PM
pnoyryder's Avatar
pnoyryder
i just installed nf210 and it lowered 1.2 it might be a lil bit more. now my tires the upper part is inside the fender and the bottom is kinda sticking out. i talked to the shop and they said that the rear has a camber that they can adjust but not the front. so do i just need to buy the front camber kit?? if they align the rear would they able to fix it?? please help
Old Mar 17, 2008 | 02:43 PM
powerofz's Avatar
powerofz
i have the eibach sportline springs.. i believe they drop to about 1".... i know i need the camber arms but do i need the camber toe kit too??
Old Mar 17, 2008 | 08:15 PM
redmike_02's Avatar
redmike_02
By investment I mean with the added adjustment you won't be replacing tires as often from crazy camber and toe settings. I'm just saying it is a good idea if you want to get back to specs and have good tire wear.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
