? for those who replaced brakes with OEM Brembos
Originally Posted by SOLO-350Z
Yea I really need to get one of those. I always have to get someone to do the brakes for me. :P
Where did you get one from and how much?
http://www.jscspeed.com/php/search.p...yword&id=bleed
As long as you don't let the fluid get low you won't get air in the system. It just puts pressure on the fluid to help push it down.
'12 TL SH-AWD
Originally Posted by DavesZ#3
I actually borrowed one but I'm ordering my own from JSCSpeed, one of the sponsors here. Their site lists them for about $54 but I believe the price will be lower if you PM them here. It's a Motive Power Bleeder:
Awesome! Thanks man, waiting for a reply from them and I might just buy one now.
on
vacula ftw
open bleeder connect vacula have it on for as long as you want. Disconnect, close bleeder. eeeasy
if you dont want to get it.
Have a friend help you, its not very safe though if your on jack stands. Have him sit in the car pump the brakes about 5 times and have him press the brake down as hard as he can and have him hold it while you open bleeder. He has to keep pressing brake pedal down while its spilling out, when its done close bleeder and he can let go. But make sure you're bleeding in the proper bleed sequence.
Originally Posted by tware
which? where? got a link?
It's nice. Fluid comes out SLOW but it's nice.
I'm wondering if a vacuum bleed would work just as well?
on
i'm about to install all four brembo calipers, rotors, pads, etc tomorrow.
question:
do I have to install the calipers in any order (for example, driver rear, passenger front, passenger rear, driver front) or is that just the bleeding process?
question:
on
i just read some stuff on *********.
davesz#3, I could really use your input since you went from non-brembos to brembos.
i read that when installing the brembos..you'll have to do some cutting in the rears to get the brembo rotors to fit. did you have to do this?
also, someone said for our nissans go from driver rear, passenger front, passenger rear, driver front. and that the one you mentioned was the "old school" way.
#38
on
Originally Posted by SpoilsofWar
^ The non brembo brakes have a smaller dust shield that surrounds the rotors, you will have to trim this to fit the larger rotors of the brembo setup. Its pretty self explanatory once you look at it.
Joel
