hotchkis rear sway bar bushing grease fitting
So I finally get around to installing the hotchkis tvs kit - everything fits and its a pretty easy install.
One thing I did notice was the rear bushing supplied by hotchkis has no hole in it for the grease to get to the swaybar.
So if you try grease the bushing all you doing is putting grease between the bushing mount and the outside of the bushing, no grease will reach between the swaybar and the bushing.
No biggie, I drilled a small hole in the bushing to rectify this.
I suggest people who have installed hotchkis rear bars with zerk fittings should check for this next time they need to grease their bushings.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
