Will I need to correct my camber?
Old Mar 28, 2008 | 08:05 AM
oneradtek202's Avatar
oneradtek202
Default Will I need to correct my camber?
Im going to be putting on a eibach pro kit and i think it lowers me an inch after all said and done.....will i need to worry about correcting my camber? I wont be driving it too much, it sits in my garage 3 days a week. I want some better handling which i know a negative camber will give me, but will i need to put a correction kit on the car for only an inch? i did back when i lowered my civic 2.5 inches, so im thinking that if i dont drive it daily then tire ware will be a minimum
what you all think?
Old Mar 28, 2008 | 08:42 AM
Sick Z's Avatar
Sick Z
All cars are different on how bad the camber will be after lowering. With 1'' you shouldn't have any problems getting the rears within specs with the rear stock arms. Either way, you should take the car to the alignment shop after letting the springs settle to see where it sits. Example: On my Z I installed GF210s and the shop was able to align it back to oem specs, where my buddy installed H-techs on his car and his camber went out pretty bad.
Old Mar 28, 2008 | 09:30 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
anything above 1" most def...so maybe you will be lucky..
Old Mar 28, 2008 | 09:38 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
GF210s have a 1.2" drop in the rear. What is your definition of "back to OEM Specs" ? FYI getting your camber back to -2.1 is no where near close to the ideal OEM specs.
The main objective is to get your rear toe back within OEM specs. 0.08 is ideal for the rear.
Old Mar 29, 2008 | 07:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
ideal is a relative term.
Old Mar 29, 2008 | 07:22 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
i have a tanabe
Front is close to spec ( no camber arm )
Rear is enough to adjust ( SPC camber/toe )
got mine from adam@z1auto
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Depravity
Oct 1, 2015 04:49 PM
