Tokico D-Specs 9/ Eibach Sportline Lowering Springs
Old Apr 2, 2008 | 09:05 AM
ErinFaulk's Avatar
ErinFaulk
Default Tokico D-Specs 9/ Eibach Sportline Lowering Springs
I just ordered the Tokico DSpecs 9 as well as the Eibach Sportline Lowering Springs.
Is there anything else I might need? Currently I am running 275/35/19 x 10.5 in the rear will I have any rubbing?
I am not sure if I would need to do the bump stop mod, would this be necessary with this setup?
Any advice would be appreciated.
Thanks
Erin
Old Apr 2, 2008 | 09:47 AM
usmanasif's Avatar
usmanasif
For rubbing, take a close look at how much clearance you now have and how much lower the car will be once the new springs full settle. Check both sides of the wheel for clearance and you will get an idea. This will depends a lot on your wheels' offset.
Old Apr 2, 2008 | 09:52 AM
InZomniac's Avatar
InZomniac
It cannot be calculated without the offset of the wheels
Old Apr 2, 2008 | 10:21 AM
350ZPK's Avatar
350ZPK
If offets are over 20..you'll be fine.
Old Apr 2, 2008 | 11:21 AM
ErinFaulk's Avatar
ErinFaulk
Thanks, I will be fine then.
Old Apr 15, 2008 | 05:33 PM
ErinFaulk's Avatar
ErinFaulk
I had them installed, and put on my summer wheels, now it looks like I need a camber kit. Any suggestions with this setup?
Old Apr 15, 2008 | 05:45 PM
sk26dett's Avatar
sk26dett
Spc camber and toe kit worked well for me when i was on sportlines. pm some of the sponsors on here, i think they have the best price.
EnjukuRacing
Sep 30, 2015 06:55 AM
