Hooking up at the track.
get some drag radials...bf or nitto..as for suspension i have this...
http://www.kinetixracing.com/index.a...&ProdID=8&HS=1
along with cusco zero-2 coilovers
pm a vendor for better then retail pricing....
I don't think we have really scratched the surface as far as what specific suspension changes benefit what goes on dynamically at launch and how to best promote adheasion.
IMO, post the same question in the drag racing section. But with this title instead.
"What kind of suspension tuning will lower my 60' times at the track?"
Shocks, or coilovers, what dampning settings do I use?
Is adjusting only rebound better?
Front/ rear spring rates, what direction is best?
What your looking for isn't so much a one size fit's all approach.
Not all shocks and coilovers adjust a equal amount of compression and rebound dampning with some claiming compression adjustablity with rebound but delivery very little compression adjustment (I suspect that Tein flex is that way). Some shocks and coilovers only have rebound adjustablity, Koni sports, Kw Variant 2 and Ohlins PCV/DFV.
Hope that helps.
Hope that helps.
etkms
Jun 19, 2022 06:30 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
