tein basic height adjustment
LOL , Basics use the same rear coils setup as most other coilover for the Z. The rubber Spring seat gets removed to install the spring and adjustment assembly. You would know that if you worked on these cars.
Originally Posted by Zman636
Hmm...is it ok that I spun the collars up on my rear springs with damper still connected? I still had all the tension on it. I do know that the whole spring was spinning in the bucket while doing this but made sure that before I let the car down that the spring was sitting in the bucket right.
Also does the rubber mount on the bottom of the stock spring have to be mounted on the aftermarket coils? I'm assuming so and that is what I did.
Originally Posted by Z1 Performance
many coilovers call for retention of the stock rubber conical upper "mount" for the rear springs
and the tein install instructions even show this to be true.
it won't matter because your rear damper is not height adjustable, since the Basic's are only 1 way height adjustable. So rideheight is a function of spring preload. The rear rubber piece does get reused with the Basic's per the instructions that are included with the kit (ZO4 just posted the link as well). If you find the rear height is not adjustable enough for you, you can also trim the rear rubber conical piece as well (at flat round side, not the cone side), and height will additionally drop by the amount you trim it.
Well, I don't have the basics. I have the zero-2s, but assuming it is the same with cusco as well? But I was wondering if there is a problem with adjusting the rear spring collars with the spring bucket connected/the damper connected? This is also while the car is jacked up and the wheel removed. Sorry to sound confusing. Thanks
