Megan Racing Track Series Coilovers
Originally Posted by Lawy'dU
Megan's and D2's are made by the same company (BC Sports) I believe. They are really the coilovers...
JET
Originally Posted by A.H
What wrong with the stance true coilover rear 12k/11k as i purchased them. lol.
The 12Kg/11Kg setup run the rear springs in the oem location.
Originally Posted by JETPILOT
The only potential issue with the rear true coilover is that it places alot of stress on that rubber bushing the shock mounts to as it is now bearing the weight of the vehicle. Keep an eye on it as it can be crushed/torn. I have a true coilover rear as well and I have had no bushing issues yet after 18,000mi.
JET
JET
http://www.splparts.com/main4/parts/...oiloverFAQ.htm
In the reciept it says i got 12/11 gr+ true coilover. Are you saying this isn't avaliable and what i got what the stock location for the rear? Cause after reading that i hope i didn't get teh true coilover...
http://www.stance-usa.com/plus_apps.php
The receipt could be wrong in two way's, the true coilover part, or the 12/11 part. Makes you wonder either way.
You think we are the only ones doing this?
Here is an Eibach/Callaway coilover setup for a C6 Corvette.
KW Variant 3 for c6.
It's done on BMW's as well.
Zeal Function R is a true coilover in the rear. The mentality around here used to be well if Zeal isn't doing it then it can't be beneficial. Well now Zeal is doing it. There must be a reason.
JET
JET
^^^^I like that point. IF the top of the line brand uses a true coilover for the rear they must know somethign that we don't. Since they are trying to provide the best handling charecteristics possible you woudl think they know the best possible postion to put teh rear springs and im sure they have put time and effort into this process.
JET
JET
Zeal does also makes a oem spring location setup for the Z for both the X and XS coilover. I could never find enough info on zeal to bite into to really get interested, in spite of all the shout out loud opinion's everywhere. I did notice that their truecoilover setups have really high rear wheel rates.
The Unitech Grand Am car Sasha purchased also had true rear coilover suspension. He is however putting the spring back to OEM location for undisclosed reasons.
JET
JET
Sending the rear shocks and spare rear shocks to Truechoice KONI this week to have them all rebuilt, and am going from the single ground-control spring on shock setup they were using to the way unitech was doing it with the OEM spring on the lower control arm and shock, its actually a really neat design they have the height/preload adjustment through the trunk, nascar style
Maybe Unitech went with a true coilover after the True Choice and he is going back to the way it originally was??? I think that's what it says.
JET
I can tell you that when BC o.e. manufactures others coilovers, it is to the requesters design specifications, not BC's design. The BC racing coilover that is labeled BC, is a BC design.
I think more than a few of you here would be very suprised at what expensive JDM brands are also made by BC as an o.e.
Since i dont' want too high of spring rates to bounce around everywhere on the canyons i think i want to go with 12/5 or 12/7 spring rates but i still do not know if i shoudl go OEM in the rear or True coilover
JET
I just had an interesting conversation with Truechoice and they stated they are customer driven and will build you whatever you want. He said the Unitech team had decided on keeping the OE spring location. So there you have it.
JET
JET
The Koni Truechoice Stage 3&4 coilovers are true coilovers.
JET
JET
