Tein Flex Coilovers
Old Apr 24, 2008 | 10:52 PM
VQ_Z's Avatar
VQ_Z
Default Tein Flex Coilovers
How are they compared to the factory suspension? Stiffer? Bouncy? Any noise when hitting a bump on road? How does it feel when you're behind the wheel? I would like to learn more about this setup as i am looking for a full coilover setup this summer
Old Apr 25, 2008 | 01:04 AM
FlyingSquirrel's Avatar
FlyingSquirrel
I have the tein mono flex w/edfc.
It's not too harsh at all. GT didn't even know the difference after I installed the setup. I dropped about an inch all around, not too bouncy either. Only complaint is that the dampening isn't really that noticeable when adjusting between levels 0-16.
There was a clanking sound when I initially installed the coilovers. Make sure and hit the top bolt with an impact gun before installing. Clanking sound went away after I tightened up the bolt and reinstalled the red circular (doughnut) that came with the factory setup.
I'd give the system a 7.5 out of 10, need wider range of adjustability. I do like how the edfc looks in the cubby though.
Old May 2, 2008 | 05:40 AM
FlyingSquirrel
1000 miles later, damn ish started to rattle again.
Old May 2, 2008 | 07:02 PM
luttmeister's Avatar
luttmeister
I've had the Teinflex w/ EDFC on my '04 Roadster (lowered about a half inch) for about 2 months now. They're great for highway and track, definitely stiffer than stock, but not too bouncy unless you set them on a soft setting where you'll get a lot of spring bounce.
If you don't want a setup that's much stiffer than stock, consider the Tein Comfort Sport - still very adjustable but softer spring rates - maybe better for daily driving (and EDFC compatible).
Old May 20, 2008 | 10:13 AM
PFunk124's Avatar
PFunk124
Great post. I've justed installed the coilovers flex and hear a bit of clicking noise in the back. Just need to try and tighten the bolt and put the red donut ring.
Old May 25, 2008 | 08:27 PM
citymunky's Avatar
citymunky
Thumbs down Washers???
I just installed my Flex types on friday, and when I drive I heard clicking noises also. It almost sounds like I'm dropping dimes as I drive by. I think those washers on the damper rod that's making that sound. How did you fix that??
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
