Did alignment today with Ken(Specs Inside)
Old May 1, 2008 | 10:53 AM
chinny's Avatar
chinny
Default Did alignment today with Ken(Specs Inside)
What do you guys think of these specs?
Old May 1, 2008 | 10:54 AM
chinny's Avatar
chinny
Is it hard to read or is it just me ?
Old May 1, 2008 | 10:57 AM
chinny's Avatar
chinny
http://s4.photobucket.com/albums/y11...nt=Picture.jpg
is the direct link
Old May 1, 2008 | 11:01 AM
chinny's Avatar
chinny
BTW, it was done on a Hunter over at Alignment Factory.
Old May 2, 2008 | 04:12 AM
chinny's Avatar
chinny
He was able to get the rear back into -1.8 camber with no kit. Specs speak for themselves.
Old May 2, 2008 | 08:22 AM
redlude97's Avatar
redlude97
Was this done with you in the car or with a ballast in the driver's seat to simulate your weight?
Old May 2, 2008 | 08:49 AM
chinny's Avatar
chinny
No it was not, i actually was going to ask him to let me sit in the car but i dont think ~170lbs would make that much of a difference. I can be wrong also. But with stock camber arms and toe bolts he did a good job. I wish i can make the scanner scan a little more clearer, or can i ?
Old May 2, 2008 | 11:38 AM
redlude97's Avatar
redlude97
It will make a difference, any good alignment shop should let you do that.
Old May 2, 2008 | 11:39 AM
redlude97's Avatar
redlude97
He should also fix the toe in on the front, they vary too much and should closer to 0.04
Old May 2, 2008 | 12:32 PM
chinny's Avatar
chinny
I think im going to go back to re-do the toe in the front again. Hes a cool dude.
Old May 2, 2008 | 08:21 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
now its time to fix your front...because those results stink quite honestly (you need a arms, badly)
not sure where the surprise is here though... you've got mild springs, and a mild wheel and tire package, so really no reason a new car should be badly out of spec after an alignment given those conditions.
3vilbunny
Jul 18, 2017 05:10 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
