Confused on Tokico Adjustment
Old May 5, 2008 | 08:30 PM
tnk210's Avatar
tnk210
Default Confused on Tokico Adjustment
I'm having issues with understanding how to adjust my Tokico D-Specs. I bought these off a member so no install instructions. From reading other threads it appears as though all you should need to do is insert a hex wrench but I don't see where to adjust them.
Attached Thumbnails Confused on Tokico Adjustment-img_0210.jpg   Confused on Tokico Adjustment-img_0211.jpg
Old May 5, 2008 | 10:34 PM
JJ19's Avatar
JJ19
hahahah, u just twist off the metal cap..that's all it is and then you'll see where u can "stick it"!
Old May 5, 2008 | 11:01 PM
black06z's Avatar
black06z
Yep. Just twist off that cap on the 2nd pic and insert the adjustment tool. Be careful not to drop the cap in the engine bay once the shocks are installed though.
Old May 6, 2008 | 06:38 AM
tnk210's Avatar
tnk210
Thanks fellas!
Old May 6, 2008 | 07:18 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
+1
Mine is gooooooone
Old May 7, 2008 | 11:03 AM
tnk210's Avatar
tnk210
I installed the rear shocks last night because of the ease, but was suprised when driving to work today. My fenders are rolled just enough to clear but with the settings I had the Tokicos on the drivers side would rub on a hard right.
I have them set one full turn left from clockwise lock, so I thought it would be stiffer?
Old May 7, 2008 | 11:05 AM
Mazinger Z's Avatar
Mazinger Z
Yea, that should be right. Right --> Stiffer. Left <--- Softer. What kind of springs do you have? Installing shocks shouldn't make anything "rub".
Old May 7, 2008 | 12:33 PM
tnk210's Avatar
tnk210
GF210's. It may be stiffer but maybe because of the Dspec adjustabilty changing, the rebound is now softer than it was for stock? That's the only reason I could think of. Probaly just need to roll the fender a bit more.
Old May 7, 2008 | 02:45 PM
Mazinger Z's Avatar
Mazinger Z
Did it rub before you put on the shocks? Or did you put springs + shocks at the same time?
Old May 8, 2008 | 07:02 AM
tnk210's Avatar
tnk210
Springs were already installed before shocks.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
