View Poll Results: to wilwood or not?
wilwood is the chit !
35
55.56%
get AP !!! < - ha ha !
28
44.44%
Voters: 63. You may not vote on this poll
to wilwood or not
Old May 15, 2008 | 09:11 PM
JETPILOT's Avatar
JETPILOT
Originally Posted by opathal
All that test showed me was that Stoptech are not worth the money over OEM Brembo. Unless you're going for eye candy. Also, temps may have a lot to do with rotors. The Stoptechs use the aerorotors which are far superior to the OEMs. I was personally expecting a far better showing from Stoptechs.
If the OEM are that good, I wonder what the Brembo GTs can do.
Your crazy! Talk to 2fast4u. I watched him go off the track in front of me at Sebring a few weeks ago becasue his pedal went to the floor with the OEM Brembo's. He wasn't even running R-compound tires. In addition he is on a stock motor = low top speed on straight aways. The only mod he had was his NISMO pads.
Stop magazine racing and get on a track.
JET
Old May 15, 2008 | 09:57 PM
terrasmak's Avatar
Wilwoods here and i track mine. There is a great selection of pads directly from wilwood and most major pad companies make them too. http://www.tceperformanceproducts.co...s.pl?record=18
Old May 16, 2008 | 07:57 AM
Tac-M's Avatar
Tac-M
Originally Posted by JETPILOT
Stoptech ST-40 4 piston front kit 355 (14") black, silver, red. Axxis ULT pads and SS lines. $1995 shipped. Zinc coating on rotors $65 extra.
JET
that is wayyy more ....
Old May 16, 2008 | 08:04 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Than wait and save. I waited damn near 2.5 yrs before getting my BBK. Go StopTech! You won't regret it.
Old May 16, 2008 | 08:17 AM
Tac-M's Avatar
Tac-M
^ that is the plan. i am not rich enough to buy things twice.
Old May 16, 2008 | 08:21 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old May 16, 2008 | 08:26 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OP: https://my350z.com/forum/brakes-and-suspension/326163-big-brake-kit-picture-thread.html
Old May 16, 2008 | 12:30 PM
redlude97's Avatar
redlude97
BBK's are for added heat capacity, not shortened stopping distances, I wish people would get that through their thick heads. A stoptech 4 wheel setup will have significantly higher heat capacity and dissipation capabilities compared to the OEM brembos. That is where they shine
Old May 16, 2008 | 02:37 PM
Tac-M's Avatar
Tac-M
^ ok, so how much less heat capacity an original wilwood kit will have ? so for me , not going FI and NOT trying to become speed racer, willwood should be fine, and i can take that grand that i would save and use it for DE / track time / new tires... right ???
Old May 16, 2008 | 06:44 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
The StopTechs are a larger rotor & Caliper that will displace heat more. If you're doing anytrack time invest in the StopTechs. Also the WilWood rear kit doesn't offer the parking brake.
Old May 16, 2008 | 09:53 PM
OnADimePBS's Avatar
OnADimePBS
Right. More then fine TBH
This is false information. I encourage you to call Wilwood if you don't believe it.
Wilwood rear kits for the Z33 will use the stock ebrake. Prior generation kits/hybrid kits may not have but the most recent Factory kit does.
Old May 17, 2008 | 01:03 AM
terrasmak's Avatar
Really ?? I'm running a 355mm 2 piece kit from wilwood on mine. How much bigger are the stoptechs ?
Old Oct 29, 2008 | 12:46 PM
Tac-M's Avatar
Tac-M
wilwood it is. 14" front - 13" rear. black, sloted rotors.
Paul @ ART got me a DEAL !
http://www.advancedracetechnology.net/
Old Oct 29, 2008 | 01:37 PM
terrasmak's Avatar
I have the same setup on my car , you will love it. I highly recomend a set of Poly B pads for track use.
Old Oct 30, 2008 | 05:10 AM
Triple8Sol's Avatar
Triple8Sol
Wilwood makes great race-proven, time-tested braking components. You can't go wrong with kits directly from them, or from reputable companies that have pieced them together with R&D.
Old Oct 30, 2008 | 09:42 AM
Tac-M's Avatar
Tac-M
my kit is 100% wilwood - that is what i was told.
Old Oct 31, 2008 | 09:51 AM
vallini's Avatar
vallini
Wilwood on all 4 corners. Got from Paul at ART. Looks great and feels great on the street. Wilwood gave great tech support during the install and backs up their product. Enough said!
Old Oct 31, 2008 | 10:45 AM
  #38
ZRuggernDC's Avatar
ZRuggernDC
Contact PaulGT2 for pricing. And trust me... Worth every penny. Also, IMO, a much better kit than WilWood. I would buy some used OEM Brembo before the WilWood Kit.
+10000000000
Paul's awesome!
Then I sent em to OnADimePBS to get them powdercoated candy blue... ... mmmmmm, the hotness
Old Nov 1, 2008 | 09:30 AM
  #39
C Ray Z's Avatar
C Ray Z
Default Road Raced
I have had my kit for five years. I have road raced for the past four. I replace my pads from wear each year and have not had to perform any maintence other then clearing the pistons of dirt and rubber prior to installing new pads. These have been great. I do have cooling for the front brakes. I have 6 pot front and 4 pot rear. Great brake kit.
Old Nov 1, 2008 | 05:32 PM
  #40
Tac-M's Avatar
Tac-M
^ wilwood right ? if what you say is true, i am very happy !
