HKS Hipermax III Coilover Impression/Review
Old Jun 15, 2008 | 07:55 AM
aloh's Avatar
aloh
Originally Posted by bilal83
What do you guys mean that they are not a true coilover set becasue of the rear?
yes. If you look at how the OEM rear setup is, the springs are on a diffferent location than the shocks. A "true coilover" setup is like the front where the springs are on the actual shock.
Old Jun 24, 2008 | 11:16 AM
maomao's Avatar
maomao
Hi,
It is an excellent review and message.
I am also considering HKS Hipermax III coilover. Just wonder if there is any noise or rattle after you fit the coilover? Also, how stiff it is when you adjust the coilover to the stiffest setting?
Thanks
Old Jun 24, 2008 | 04:46 PM
Doh-Joe's Avatar
Doh-Joe
Glad you liked the review.
I've had these for almost 2 months now & no noise or rattle what so ever. I haven't messed around with the dampening settings yet because the default HKS setting (middle) is just too comfortable & still able to slice the street corners like butter. Although I probably should sometime in the future for further review. Anyways, if your looking for something practical & pass the "wife test" then look no more. If your looking for something with a little more track-race-car like characteristics then these might not do for you.
Old Jun 24, 2008 | 10:51 PM
maomao's Avatar
maomao
Hi,
Thanks for your reply.
Did you try KW or Ohlins before? I learnt from others that KW is similar to HKS Hipermax III in terms of comfort and Ohlins is more stiff than HKS Hipermax III, true?
So, if I turn the Hipermax III to the stiffest setting, can it achieve track-race feel?
Thanks
Old Jun 25, 2008 | 04:54 PM
Doh-Joe's Avatar
Doh-Joe
Originally Posted by maomao
Hi,
Thanks
I have heard few good things about KW, I've never heard of Ohlins and never experienced either of them. Sorry, I don't know what else to tell you.
Old Nov 17, 2011 | 05:12 PM
Doh-Joe's Avatar
Doh-Joe
Updated thoughts on 1st post.
Attached Thumbnails HKS Hipermax III Coilover Impression/Review-p7180075.jpg   HKS Hipermax III Coilover Impression/Review-dsc_0176.jpg   HKS Hipermax III Coilover Impression/Review-2010-tx-state-fair-011.jpg   HKS Hipermax III Coilover Impression/Review-2010-tx-state-fair-020.jpg   HKS Hipermax III Coilover Impression/Review-3rdday203.jpg
Old Feb 1, 2012 | 12:30 PM
xman2yman's Avatar
xman2yman
Hey I am thinking of buying a set of these used for a good price they have about 8k on them, would you recommend these? even with that kind of miles?
Old Feb 1, 2012 | 01:22 PM
Doh-Joe's Avatar
Doh-Joe
I have rode on this set for nearly 50k miles (daily driven) with no issues at all. Not sure what you're planning on using it for but I would recommend it for street and maybe some track use here and there. If you plan on dumping your car and stretching your tires, look elsewhere.
Old Feb 1, 2012 | 01:24 PM
Duckeee's Avatar
Duckeee
buy them, you will have no regrets unless you want to lay frame. these coils go low with the collars removed, but going that low alters your handling negatively.
Old Feb 1, 2012 | 01:31 PM
Doh-Joe's Avatar
Doh-Joe
^ What Duckeee said. Those pics on post #25 are the lowest I can go I believe without compromising my rebound capabilities.
Old Feb 1, 2012 | 03:13 PM
xman2yman's Avatar
xman2yman
Yeah I think with 7k miles at most on them they are worth it at 1000 shipped.
Old Feb 2, 2012 | 08:36 AM
Gsedan35's Avatar
Gsedan35
I knew I had HKS III drop specs saved somewhere, here ya go
HKS III recommended drop, min/max drop
In mm
Recommended drop -9mm/-11mm
Min drop 0mm/0mm
Max drop -40mm/-49mm
In inches
Recommended drop -.4”/.4”
Min drop 0”/0”
Max drop -1.6”/-1.9”
http://www.hks-power.co.jp/db/produc..._ID=433&M_ID=2
Stevo Z
Oct 3, 2015 09:14 PM
