Waiting for help!...Quick Question!..Im Stuck during install!!
Old May 25, 2008 | 04:38 PM
shabz's Avatar
shabz
Default Waiting for help!...Quick Question!..Im Stuck during install!!
Im installing the SPC toe bolts and i understand that i gotta remove the stock ones so i can elongate the holes... now when i remove the stock bolts the spring bucket will come down!.... will i be in danger doing this??... wont the spring just fly!!?...
im under the car ready to take off the toe bolts... someone help me!
Old May 25, 2008 | 05:05 PM
Spork's Avatar
Spork
for the rears? If your car is up on jack stands with wheels removed... Use a floor jack to keep pressure on it.
Old May 25, 2008 | 05:08 PM
Rowlett's Avatar
Rowlett
A jack position under the spring bucket will hold the tension then release the jack down.... Two jacks help when doing this install.... I used my spare tire jack...
Old May 25, 2008 | 06:11 PM
shabz's Avatar
shabz
thanks guys!... too bad that wasent mentioned in one of the write ups i found!
Beater350z
Sep 9, 2015 03:36 PM
