abs engaging too early
Old Jul 3, 2008 | 12:32 PM
BrickyardBomber's Avatar
BrickyardBomber
Originally Posted by kevin8086
under the hood there is a fuse block and there is one large fuse that actually has 3 fuses integrated 2 abs and 1 ign. i did use electrical tape for the time being to not allow the prongs for the 2 abs fuses to touch but allowing the ign prong to touch. I will be looking to see if there is a 40amp replacement at a parts store so i can pull the 3 fuse block out and run just the 40 amp for the ign. if you look on the cap it will show abs, abs, ign
30 30 40 it has a clear cap that can be removed. you can also just break the 30 amp links for the abs but leave the ign one alone and that will also work but i chose not to.
Awesome info. thanks bro.
Old Jul 4, 2008 | 06:34 AM
Q45tech's Avatar
Q45tech
Careful about publically exposing safety modifications to the NET as mods which delete or modify ABS/Air Bags, change brakes/suspension could be insurance fraud if the vehicle is used on street.
Don't admit things to the world or courts system, GUILT especially with a permanent record.
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
