Quick Brembo Bleed Question...
Old Jun 20, 2008 | 09:48 PM
gr8scott_o's Avatar
gr8scott_o
Default Quick Brembo Bleed Question...
Are you supposed to bleed from both bleeder valves on each caliper?
Thanks
Old Jun 20, 2008 | 09:50 PM
DogZilla's Avatar
DogZilla
Thanks
Yes, you need to do both sides of each caliper.
Do the outside valve first, and then the inside.
Old Jun 20, 2008 | 09:56 PM
JETPILOT's Avatar
JETPILOT
What he /\ said.
Old Jun 20, 2008 | 10:04 PM
ZTEALTH's Avatar
ZTEALTH
actually, according to Brembo's instructions, bleed the inside before the outside of each caliper. in this order: Right Front -> Left Rear -> Left Front -> Right Rear.
Old Jun 21, 2008 | 03:16 AM
gr8scott_o's Avatar
gr8scott_o
Thank you all very much!
Now, at 5:00 a.m. I go out finish the job I started last night - ha!
Old Jun 21, 2008 | 04:04 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Inside first, then outside
Old Jun 21, 2008 | 08:45 PM
saladito6's Avatar
saladito6
Not to be a a-hole, but I bled my brakes today and the Nissan Service manual for the '03 says to bleed the calipers in the order of: Left Rear, Right Front, Right Rear and Left Front. I get the fact that the left rear goes first because the line is the longest, but I don't get why the right front is second because it has the third longest line. I did it anyways though and it worked pretty good.
lapham3
Oct 7, 2022 03:15 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
