tanabe NF's + tokico d-specs???
Old Jun 23, 2008 | 01:15 PM
mond's Avatar
mond
Default tanabe NF's + tokico d-specs???
how's the combo of these two? really looking for comfort and i wanted to know if this will give it to me... also, any other recommendations on the shocks/spring area to improve comfort? thanks much
Old Jun 23, 2008 | 01:32 PM
ZGoblinTT's Avatar
ZGoblinTT
I had the normal feel tanabe springs on stock shocks and the ride was a little bouncy but with good aftermarket shocks it will knock that out. Its a soft spring! To tell you the truth I couldnt tell the diff. between stock setup Vs. Tanabe NF besides the ride height!
Old Jun 23, 2008 | 02:07 PM
moforeynolds's Avatar
moforeynolds
As far as recommendations go, I have Eibach Sportlines with Tokico Blues and I love the look and ride. The ride quality is near stock; slightly harsher but not bone-jarring like you would get with most coilovers. The Blues are non-adjustable, but that was not a concern for me. Springs, dampers and all proper alignment parts (front arms, rear arms and toe) totaled less than $1000.
The drop is a bit lower than the NFs, which I preferred. I am fairly certain it's as low as you can go without coil-overs...but I don't deal with a bouncy ride, either
More pictures here:
https://my350z.com/forum/media-share/364938-single-pic-stock-on-sportlines-and-spacers.html
Old Jun 23, 2008 | 09:35 PM
guzzie23's Avatar
guzzie23
does anybody have any pics of the NF's with the stock 18's on it? I'm thinking of going with them, just wanna see how much of a drop it is...
Old Jun 23, 2008 | 09:48 PM
THE_SCHROED's Avatar
THE_SCHROED
Here is a pic of the NF's on stock 17" rims with a 20mm spacer in the front and a 25mm in the rear. I have had them for a little over a year and to tell you the truth the ride isn't very bad. People ***** and complain all day about them on here, but no one ever notices when they ride with me and I don't feel that it is too harsh.
Old Jun 25, 2008 | 11:30 AM
ResIpsa's Avatar
ResIpsa
On the issue of soft springs with D-Specs (I am running H-Techs), this setup gives you the advantage of being able to run real soft if needed.
If you install stiff springs your stuck with a stiff ride regardless of damper setting.
Old Jul 6, 2008 | 07:41 AM
Cide's Avatar
Cide
i have the GF's and the D'Specs and i love the set up
Suffolk350z
Sep 13, 2015 02:43 PM
biscotti
Aug 8, 2004 11:17 AM
Gsedan35
Mar 21, 2004 11:02 AM
