S2000 like suspension?
Old Jun 24, 2008 | 03:56 PM
Zacreth's Avatar
Zacreth
Z Rocker
Default S2000 like suspension?
I'm curious to know what mods I could do to better the suspension so it would feel like my S2k that I had. I had the early model s2k btw and not the '04 or newer with the softer ride.
I didn't mind the handling at all and when I got my 350 if felt heavy at first and I was uncomfortable traveling fast in the corners. I can feel the body roll and was unsure that if I pushed it more it would break loose.
Having own the 350 now for 6 months, I can push the car harder than I did when I first bought the car, but I still feel the roll into corners.
Would swaybars be a good decision or should I go with coilovers and swaybar?
Any suggestions would be great.
I just mainly drive it on the street but may eventually when I get some time go to the autox track every once in a while to join some friends.
Thanks
Old Jun 24, 2008 | 04:26 PM
NismoZ350's Avatar
NismoZ350
It's never going to feel like the S2K. There's nothing you can do to make it feel like that. Sways and Coils will make it feel a lot flatter in the corners though. I think it's a worthy investment.
Old Jun 24, 2008 | 05:01 PM
Axelerate's Avatar
Axelerate
Sure it can.
Really stiff springs with proper dampers can do wonders.
Old Jun 24, 2008 | 05:14 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if your biggest complaint is body roll, your first mod should be swaybars
you also might want to look into a lowering spring with an increased rate vs stock, which will lower the cars cg, and also assist in reducing the side to side "roll". Or, if your budget and needs can handle it, a proper set of coilovers, coupled with the swaybars
Old Jun 24, 2008 | 05:52 PM
Slow*Jim's Avatar
Slow*Jim
Want to make it feel like an s2k? Sway bars and weight removal. You can easily remove close to 100lbs from our cars with a minimal investment and very little loss in daily driveability.
Old Jun 25, 2008 | 07:37 AM
Zacreth's Avatar
Zacreth
Z Rocker
So I don't mind buying a decent set of coilovers and sways. Which all the companies out what would be the prefered brand? I was doing some searching and there is just way too much info for brands.
I'm familiar with the populars such as Tein, Jic, Moton, etc. What would be the ideal? I know that with Tein's EDFC that I can change the damping inside the car whereas the others don't provide that.
And for sways i found everyone recommended hotchs... any other preferred brands?
Thanks for the info guys.
Old Jun 25, 2008 | 07:42 AM
Z1 Performance
Former Sponsor
step 1: set a budget
Old Jun 25, 2008 | 07:49 AM
z-u-later's Avatar
z-u-later
Step 2 - Do more "SEARCH" . . . plenty of information already in the forum regarding suspension setups, to include visiting the vendor suspension classifieds section. And don't forget the autocross section either.
Old Jun 25, 2008 | 07:54 AM
JSDZ33's Avatar
JSDZ33
word. what are you looking to spend OP? also are you planning on tracking it a bunch or just want it handle better for daily driving? wider wheels and tires help a good amount in the handling department as well. once you start lowering the car there are other suspension mods that I would highly recommend. the first 5K I spent on my car was suspension mods alone. starting from the ground up is the best way to mod imo (get your cars suspension and drivetrain ready for big power before adding big power, and not the other way around) some goodies to look into that made my car handle FAR better than my buddies S2K ( Coil Overs, Control Arms, Camber Links, Rear Control Arms, Sway Bars, Chassis Brace, Front and Rear Tie Brace, Light Wheels, and super wide grippy tires, I was running 265's up front and 295's in the rear)
Old Jun 25, 2008 | 11:43 AM
Zacreth's Avatar
Zacreth
Z Rocker
Well I'm looking to spend at first between 1.5 - 2k
Also I'm getting a widebody which will require me to get 11" fronts and 13" back rubbers.
So it Tein worth the money since they seem to be a little higher than other brands? I always loved the edfc...lol
Old Jun 25, 2008 | 11:47 AM
Z1 Performance
Former Sponsor
The edfc offers the convenience factory, but I find it a bit gimmicky - all personal preference though.
The Cusco Zero 2, which is what I'd personally recommend given your needs/wants blows the std. Flex away in terms of adjustability (much bigger valving span of meaningful adjustments), noise, and civility, yet comes in significantly less expensive. A set of those, coupled with some swaybars, and a front/rear camber kit would be a great setup, cost effective, and completely transform the handling of the car
Old Jun 25, 2008 | 04:23 PM
ladyzed's Avatar
ladyzed
S2K is also 400+ lbs lighter no ?
Old Jun 25, 2008 | 04:54 PM
turismo's Avatar
turismo
I was about to mention the same thing.
Your car will never feel like an S2k due to its weight. The only thing you can do is remove weight and suspension
Old Jun 25, 2008 | 05:56 PM
nismo53E's Avatar
nismo53E
i had an S2k before the Z as well and miss the more go kartish feel. after driving the nismo for 8 months, i'm pretty sure it would do most corners as quickly as the S. it doesn't have the flick of the wrist direction change, but it will take corners at least as quickly. you just have to be more careful putting the Z in the corner.
not to threadjack, but would the simple cusco/swaybar/camber kit bring improvement to a nismo?
Old Jun 25, 2008 | 08:40 PM
garage-c's Avatar
garage-c
Yes the Z is heavier, but I can still creep away from my buddies in their S2K's on track. My '03 track model has stock suspension as do my friends S2K's. Don't be hasty and assume that just because the Z is heavier and less twitchy that it doesn't perform. IMO you should get some seat time at a few DE's before you start spending money on an already capable suspension.
I will add though that adjustable suspension arms are the first thing you should do. A proper alignment will change your handling noticeably.
Just my $.02 =]
Old Jun 25, 2008 | 10:25 PM
PDX_Racer's Avatar
PDX_Racer
I've driven my Z, and both AP1 and AP2 S2Ks.
All very nice cars. My Z handles very similarly to an AP1 S2K -- except that when the back end comes out, it is pretty easy to control for me. But then again, my idea of "twitchy" is a formula car on cold slicks...
Old Jun 25, 2008 | 10:29 PM
Alang35's Avatar
Alang35
edfc is a scam... ive had tein cs and tein flex with edfc and it doesnt make up for the fact that their products are either too soft or unbearably stiff
Old Jun 25, 2008 | 10:41 PM
JSDZ33's Avatar
JSDZ33
word. tein FTL!!
Old Jun 25, 2008 | 11:19 PM
gsazabi's Avatar
gsazabi
Step 3: Buy my Zeal Function X with custom specs 16kg/mm & 14kg/mm! I'm selling it for only $2000! What a bargain!
Old Jun 26, 2008 | 08:59 AM
Q45tech's Avatar
Q45tech
FIRST, spend some time understanding the mathematics and design of suspensions.
Come to realization that tires and weight on them are 80% of handling equation and suspensions represent 15-20% at most of remainder. It is really difficult to improve things by even 4%. No matter how abusive and stiff you make the ride!
Don't let body roll confuse you, as it has little effect on tires. Body roll is just an indicator of weight transfer. You can slow or speed it up [springs and shocks, and sway bars] but you cannot change it, without changing body weight!
