Finally Ready to Lower the Z
Old 06-29-2008, 04:36 PM
_NIZMO_
_NIZMO_'s Avatar
Smile Finally Ready to Lower the Z
But I got a ton of questions............ I am trying really hard to keep everything under a grand.
Setup 1: My 1st set-up I might do is "Eibach Pro kit springs" and "Tokico D-Spec adjustable shocks" and a rear alignment kit for $800 (quoted from a vendor). Are these shocks/springs even good?
Setup 2: BC racing adjustable coils for $900 (quoted from a vendor). + I need a camber kit.
My question is, which setup would you go with (keep in mind I don't want the car slammed, so would I have any benefits getting the coils then).
Do I also need to buy a front camber kit, or is a rear camber all that is needed. I don't want to run into any tire feathering/alignment issues.
Old 06-29-2008, 05:50 PM
racerfreakxxx
racerfreakxxx's Avatar
don't go shocks and springs... get coilovers
Old 06-29-2008, 06:38 PM
Ruthless18x
Ruthless18x's Avatar
Coilovers for sure. I heard that Cusco was releasing a new set below the Zero-1 and Zero-2, called the GT. Pricing was supposed to be right around a grand but I haven't seen them yet.
What wheels/tires are you running now?
Old 06-29-2008, 06:42 PM
BornSlippyZ
BornSlippyZ's Avatar
+1 Save for the Coil overs! And if you do decide on the spring/shock combo, get the camber kit..primarily for the back tires.
Old 06-29-2008, 06:56 PM
_NIZMO_
_NIZMO_'s Avatar
Well the reason I'm not leaning to hard towards coils is b/c if I get coils I'll be paying over a grand ......Reason= coils(+ factoring in a camber kit)= 1,000+
but why do all of you insist on coils
sry if I sound ignorant
Old 06-29-2008, 07:24 PM
lgear080
lgear080's Avatar
Coils will give you many more options in the future. The BC units
you mention are an excellent choice. Have you considered straight
springs and stock struts? S-Techs might be all the doctor ordered.
Do you plan on tracking the car?
Old 06-29-2008, 07:32 PM
BornSlippyZ
Your right about the $ amount..but I am just giving you my 2 cents because I should of saved for a decent coilover setup instead of my tanabe spring and tokico shock. There is nothing wrong with this setup for the street but for future track usage I should of saved for a KW coilover set up or Nismo r-tune setup etc...thats all. Trying to save you some cash and time.
Old 06-29-2008, 07:37 PM
plumpzz
plumpzz's Avatar
I'm sorry but if its a daily driver, whats the point of coilovers?
A nice set of springs and a nice set of dampeners will probably be the best choice for a street driven car. The only advantages I see to a coilover are:
1.) Adjustable height
2.) Corner-balancing
3.) Shortened shock travel
4.) Lighter weight
5.) Stiffer springs? If you want..?
Of those five, only 2 will be adjusted, and I bet you won't touch it after its adjusted. Also, adjusting it yourself will probably do more harm than good, and I'd leave it to the pros. The final 2, you won't even notice a difference in a 3400 lb car.
In other words, I don't understand why so many people suggest coilovers over springs/dampeners. The standard spring/dampener setup runs cheaper than a comparable coilover-setup.
The only time I'd suggest a coilover setup is if you are an avid track junky..
ninja edit: I have the tockiko shocks, but on retrospec, I wouldve chosen the yellow ones..forget the name..
Old 06-29-2008, 11:48 PM
racerfreakxxx
listen... coilover are better that's that. It's just a fact. You don't have to go all out and if your not doing a big drop or anything you don't need camber. Gust go basic... you can get megan, stance, & tein bottom line coilovers for about 900 if you look around. it's not much of a drop but it's better than spending 700 on springs and struts. Even getting used coilovers is better than springs and struts. It just feels alot better.
Old 06-30-2008, 12:03 PM
_NIZMO_
_NIZMO_'s Avatar
so many mixed opinions
Old 06-30-2008, 12:06 PM
Nexx
Nexx's Avatar
you're gonna need camber kit either way. with the coil over you can control how much of a drop you want. for the price difference its a no brainer imho to get the b/c coilovers.
Old 06-30-2008, 12:26 PM
_NIZMO_
_NIZMO_'s Avatar
Will I only need the rear camber kit. And how would I go about choosing one.
Old 06-30-2008, 02:26 PM
Nexx
Nexx's Avatar
get the SPC camber kit which comes with the toe bolts as well. should run less than $200 easy.
Old 07-01-2008, 12:32 PM
_NIZMO_
_NIZMO_'s Avatar
Is $1090 shipped for a set of bc racing coils plus a rear camber kit, a good price?
and is bc...a good choice
Old 07-01-2008, 01:41 PM
Risky_Business
Quadrant 987c
Risky_Business's Avatar
Default Z1...
has a BC coil w/ rear camber and toe kit special on now. Search for the write up here on the BC coils. It has some great info and looks like it's very close to your budget.
Old 07-01-2008, 02:03 PM
pony_killer
Arada ninda apa
pony_killer's Avatar
if your going springs then go with tanabe...
coilovers you have so many options...i got tein comfort sports with edfc + spc front and rear camber kit all just sitting in my room waiting to be installed. waiting to get my hands on an arc strut bar and some cusco or tanabe sways so i can do everything together.
Old 07-01-2008, 02:38 PM
_NIZMO_
_NIZMO_'s Avatar
final question.....maybe
how hard is it to install the coils/camber kit ......any good rite-up's around?
Old 07-01-2008, 03:11 PM
Risky_Business
Quadrant 987c
Default Never...
done it but guessing 5/10? Raise car, remove wheels, remove old susp, install new susp, re-add wheels, check the "straight and arrowness" (haha) and enjoy? In the ballpark there somewhere.
Old 07-01-2008, 05:18 PM
Chad68
Chad68's Avatar
Old 07-01-2008, 05:38 PM
_NIZMO_
_NIZMO_'s Avatar
will I need a spring compressor when removing my old set-up?
Quick Reply: Finally Ready to Lower the Z
