lowering
Old Jul 28, 2008 | 02:41 PM
hollywoodbone's Avatar
hollywoodbone
Default lowering
how much does it usualy cost to lower the z. I dont mean just springs. to get it were i dont have any tire feathering. and i see a ton of different stuff from a $49 camber kit to a $700 kit. whats good to go with?
Old Jul 28, 2008 | 02:55 PM
shabz's Avatar
shabz
Get the Z-max lowering kit.. it includes the camber arms in the kit... it also includes an anti-tire feathering kit... i think it costs somewhere around $99
Old Jul 28, 2008 | 03:13 PM
marques1's Avatar
marques1
GO WITH THE SPC KIT. iT IS PRICER THAN OTHERS BUT IT ALSO HAS MORE ABILITES TO TUNE TO THE RIGHT SPECS. IF YOU WANT YOUR CARS ALIGNMENT TO BE EXACT THIS IS THE WAY TO GO. SOME OF THE OTHERS KIT WILL GET YOU CLOSE BUT NOT EXACT DEPENDING ON HOW DROPPED YOU ARE.
Old Jul 28, 2008 | 03:56 PM
chocobo308's Avatar
chocobo308
What rear camber/toe kit other than the SPC kit that does not require you to grind out the adjustment slots to install.
Old Jul 28, 2008 | 09:25 PM
marques1's Avatar
marques1
probably just about every other kit!!! you can do it man i have no mechanic skills at all. i swapped my springs and put on my spc kit. Just give yourself plenty of time for the install.
Old Jul 28, 2008 | 10:26 PM
terrasmak's Avatar
+1 , and the rewards of building your own car are great. You save money, and you can actually say that you actually did the mods.
Old Jul 29, 2008 | 04:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
grinding it takes all of 5 minutes per side...it's not rocket science, even the template is included.
Old Jul 29, 2008 | 05:12 AM
$916.25
Old Jul 29, 2008 | 08:56 AM
Faboo's Avatar
Faboo
i dont mean to thread jack but i have never owned a car that needed kits and stuff to lower......
anyways, how low can u get before u need these things..
Old Jul 29, 2008 | 09:27 AM
marques1's Avatar
marques1
if you are a 1inch or lower you will most likely need camber arms and toe bolts unless you like going through tires every couple of months.
Old Jul 29, 2008 | 09:43 AM
Faboo's Avatar
Faboo
One inch????...wow i was thinking alot more than that...but thnxs for the info
Old Jul 29, 2008 | 02:31 PM
marques1's Avatar
marques1
your welcome!!!! The rear suspension loves to camber once you start lowering it!!
Old Jul 29, 2008 | 03:46 PM
hollywoodbone
how low can i go before i need to roll the wheel wells or i rub? i was looking at the eibach sports
Old Jul 29, 2008 | 03:48 PM
hollywoodbone
also thank you to every one who has replied.
Old Jul 29, 2008 | 05:56 PM
marques1's Avatar
marques1
it all depends on the offset of your wheels. I'm lowered about a 1inch and a half and i rub. I have the spc control arms and toe bolts lowered on gf 210 springs.
Old Jul 30, 2008 | 05:11 AM
Z1 Performance
Former Sponsor
it varies by wheels, amount you lower, tires, etc. There really is no magic answer to it. Thanfully rolling fenders is neither difficult nor costly, so if it needs to be done, it's not a big deal
Old Jul 30, 2008 | 05:31 AM
sbZenth's Avatar
sbZenth
Im trying to decide between these two options for my car:
Tein S.Tech - 1.5" drop
Cobb Sport Springs. - 3/4" Front and 15/16" Rear drop
I am on 18"x9.5" Rota wheels
What kind of drop kits should i be looking into? And where can i get the SPC kit if that is what is should have?
Old Jul 30, 2008 | 05:38 AM
Z1 Performance
Former Sponsor
Tein S techs do not give a 1.5 inch drop.
Specs here:
http://www.z1auto.com/prodmore.asp?m...ing&prodid=304
For the rear camber kit, we carry both the SPC and it's less expensive cousin, the Eibach (see sig). The Eibach kit is made by SPC, and put in an Eibach labelled box...absolutely 100% identical kits, but the Eibach costs less for whatever reason. We can package the Eibach + Stech together for $365 shipped
The Cobb springs are nice as well, and we have them in stock, but I favor the Tein springs for the Z overall (Cobbs are also $50 more expensive)
Old Jul 30, 2008 | 07:03 AM
Z_Nick_Z's Avatar
Z_Nick_Z
im lowered with eibach sportlines on 18x9.5 front and 18x10.5 rear. I had to get a spc camber kit. Truthfully i need a front kit to but i can deal with out it for now. Also i got away with not having to roll my fenders.
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
