will 30mm drop cause tire wear?
Old Aug 3, 2008 | 02:14 AM
hijack's Avatar
hijack
Default will 30mm drop cause tire wear?
hi all,
about few months ago I've found info that if you install springs with drop rate more than 1inch then there will be excessive wear of internal side of tires.
is it true?
thanks
Old Aug 3, 2008 | 02:53 AM
Z04's Avatar
Z04
yes. if you drop further than that you will need to get camber arms and toe to get your alignment properly adjusted, otherwise you will have this problem.
Old Aug 3, 2008 | 03:02 AM
hijack's Avatar
hijack
will this happen with rear tires or both with front?
Old Aug 3, 2008 | 03:23 AM
Z04's Avatar
Z04
mostly the rear since that is the problem area that can not be aligned correctly. there are a few threads on ths already in this section, just look up SPC camber arms. not so sure on the front
Old Aug 3, 2008 | 06:24 AM
Q45tech's Avatar
Q45tech
Any drop in static body height increases negative camber by ~~ 0.83 degrees per inch [25mm].
Old Aug 3, 2008 | 07:59 AM
hijack's Avatar
hijack
thank you!
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
