Question before alignment
Old Aug 12, 2008 | 07:11 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Default Question before alignment
After going through my BFG DR's in under 3k I bought some new rubber today. Nitto Invo's 275/40/18's for the rear. I installed Tein S Techs not to long ago, but didn't do the camber arms. I'm getting the car aligned tomorrow and was wondering what is the closest to 0 camber I can run w/o rubbing or other problems? 0 would be strait up and down right? I was thinking maybe -1.0 or even -0.9.
Old Aug 12, 2008 | 08:00 PM
Zero camber is straight up and down yes. For handling I would not recommend zero degrees. -1 degree is recommended.
Can the technician dial in -1 degree with your set-up? Not sure. Guess you will have to wait and see.
Old Aug 13, 2008 | 12:03 AM
terrasmak's Avatar
The low end of alignment specs are 1.2 i believe , just off the top of my head. You need camber fr the car to properly handle. f your not tracking it , 1.2 will be just fine.
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
