quick suspension questions
Old Aug 26, 2008 | 07:22 PM
airborneranger's Avatar
airborneranger
Default quick suspension questions
After talking with a few members on here, I heard that Tanabe springs could bottom out because of their spring rate? I was told to go with the eibach pro kit. Also can you mix chamber kits and springs, ie tanabe springs with eibach chamber kit? thanks
Old Aug 26, 2008 | 07:31 PM
Chaser720's Avatar
Chaser720
Lemoned Z
I dont think so due to the fact that eibach or any company for that matter makes chamber kits.
Although it is possible to use the eibach camber kit in combination with tanabe springs.
Old Aug 27, 2008 | 05:09 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the tanabe have a fairly firm rate as far as springs go...a softer rate would bottom out the spring, not a firmer one, so not sure I understand what you heard (maybe you heard it wrong, or they explained it incorrectly?)
You can use any combo of spring and camber/toe kits
Old Aug 27, 2008 | 08:53 PM
Gsedan35's Avatar
Gsedan35
Adam I realize that you would not know the Tanabe spring rates by memory, but knowing the specs, their is a argument to be made. Even with 448/427 rates, 3/4" drop, Koni's and shorter then oem bump stops, I still didn't have enough bump travel in the front. That was a good part of the reason why I spend $950 on the shortened Truechoice shocks in the front.
Oem spring rates
350Z 2003/2004
Front:314 Rear:342
350Z 2004.5 to 2008
Front:314 Rear:427
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
Very wide spreads between the softer initial rates and firmer peak rates.
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Not much stiffer vs oem, IMO Eibach prokit is a better choice because of that springs higher spring rates which should help keep you off the bumpstops more often.
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Little to no increase in spring rate over oem, little to nothing added to keep you off the bumpstops
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Whiteline 350Z linear springs (control)
Front: Part # 73219,
Spring rate 365 LBS Drop: .8"-1"
Rear: Part # 73220
Spring rate 445LBS Drop: 1"-1.2"
(sold as 2 front springs and 2 rear springs)
www.whiteline.com.au/store/
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown)
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Old Aug 28, 2008 | 01:29 AM
Z1 Performance
Former Sponsor
interesting, and I see what you mean!
No free lunch as they say, and if you want the drop and travel, coilovers is the only way to fly
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
