Identify SPC part & Jack question
Old Aug 29, 2008 | 06:51 AM
CKY881's Avatar
CKY881
Default Identify SPC part & Jack question
Hi, I bought a SPC rear camber kit and it came with these, not sure what they are or how they are used, can someone please tell me? Is it like washers for the bolt? What about the other one nut? Does it go at the end of the SPC bolt
Also, can I jack the car up from the rear axle using a hydraulic jack? It says garage points, so im assumming its for those lifts.
Thanks
Old Aug 29, 2008 | 07:28 AM
mistico's Avatar
mistico
The washer is an SPC toe bolt washer, goes with the toe bolt if you decide to use it. Not everyone needs toe bolts to get back into spec.
The nut looks like a stock toe/camber arm nut.
yes, you can jack the car from the diff.
Old Aug 30, 2008 | 08:54 AM
Z_Youlater's Avatar
Z_Youlater
Bit of advice bout using hydraulic jack on the rear diff., stick a small 2x4 wood block in the between the jack n rear diff.
-Tu-
TrackFiddy
Sep 24, 2015 09:36 AM
Ace2347
Sep 22, 2015 03:12 AM
CJs_Z33
Sep 18, 2015 12:06 PM
NYGiants0186
Sep 8, 2015 10:37 AM
