How to readjust rebound after installing coilovers.
Old Sep 14, 2008 | 10:18 AM
cbasil's Avatar
cbasil
Default How to readjust rebound after installing coilovers.
Hi, I need to adjust the rear rebound on my JIC's on my 350z. can anyone help me, I dont know how to remove the plastic from the rear strut bar to get to each side.
Old Sep 14, 2008 | 02:30 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the plastic cover pops right off (there are tabs along the outer edge and 2 plastic pop 'clips' in the center. You will then need to drill a hole in the rear strut brace to gain access to the adjustment needle (assuming it's on top)
Old Sep 14, 2008 | 08:57 PM
SchismX's Avatar
SchismX
Where in the strut brace does the hole need to be drilled assuming you don't know where the adjustment needle sits? It seems like you would have to pretty much guess where the adjustment **** is and hope for the best.
Old Sep 15, 2008 | 05:01 AM
Z1 Performance
Former Sponsor
best bet is removing the shock from the car (1 bolt at the bottom of the damper, 2 at the top), and marking/drilling the hole from underneath
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
