Suspension Help.... just lowered
Old Oct 8, 2008 | 08:58 AM
hulikner's Avatar
hulikner
Default Suspension Help.... just lowered
I just lowered my Z on tokico blues and gf210s with rear camber kit. I went and got it aligned also a week after it settled some. But ever since I lowered it, I hear this noise and I know its coming from the front suspension. Its not a rattle but almost like something is loose but I have checked everything and it seems ok? It makes the noise only when I am going slow and I am going over small bumps like a gravel drive way. What it almost sounds like is that the top of the strut was not tightened down and it is moving up and down right below the strut bar under the hood, but everything seems to be tight. Any ideas????
Thanks
Old Oct 8, 2008 | 11:07 AM
hulikner's Avatar
hulikner
even though no one has responded yet, I found the top of the left strut moves a little bit so I am going to try to tighten the top three bolts again and see. If not then is it possible to tighten the top big nut on the top of the strut to much to where it compresses the spring to much???
Old Oct 8, 2008 | 11:38 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the 3 bolts dont go very tight - honestly just hand tight with a 3/8 wratchet is fine (I think they are only spec'd at maybe 20 ft lbs) - the center nut on the strut does get torqued down a fair bit though. Don't go overboard on the top 3, they are just there to secure the mount to the car, and if you go too tight, you will snap them. IIRC the center nut on the strut is spec'd to about 50 ft lbs or so. Also, make sure the spring is properly seated in the perch
Old Oct 8, 2008 | 09:26 PM
Sponge's Avatar
Sponge
You might want to take a look at your front endlinks. By dropping the car you've put extra force on this already weak part. A broken endlink makes all kinds of differnet sounds, a "pop" or even a "rattle" sometimes. I coulda sworn that my wheel bearings were going out on the front passenger side. Search for 'endlink' and it will pull up lots of issues with new sway bars and lowered cars. Just a thought.
Old Oct 9, 2008 | 04:58 AM
Z1 Performance
Former Sponsor
another good area to look too, but the endlink failure tends to be a bit more gradual, and if it's gone bad, it should theoretically be noticeable even on a stock suspension. If the noise wasn't there before springs/struts and is there now, that's probably where the issue is. Certainly worth a look though, as it is a common issue as well
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
