Tire rub....WTF...
Old Oct 8, 2008 | 05:59 AM
CELTIC Z's Avatar
CELTIC Z
Default Tire rub....WTF...
[/B] Ok, so I buy a set of 20mm spacers to get my wheels even with the fenders. Tooling down the highway I hit a low area and feel the right rear rub my fender. I know its not the spacer that caused this, I'm sure it has something to do with a bad spring, strut, shock... It's an 06 with 30k, bought the car with 3k......any ideas would be greatly appreciated
Old Oct 8, 2008 | 06:01 AM
savvy's Avatar
savvy
are you lowered? How low was the low area? need more details.
Old Oct 8, 2008 | 06:05 AM
JasonZ-YA's Avatar
JasonZ-YA
just keep driving........it happens...
but ya may wanna roll your fenders..
Old Oct 8, 2008 | 06:06 AM
CELTIC Z's Avatar
CELTIC Z
stock suspension, 275/40/18 on the rears, area was not that low, more like a dip
Old Oct 8, 2008 | 06:07 AM
My350P's Avatar
My350P
Could be the spacers. I'm dropped on NF210s, 25mm spacers, oem 5-spoke 18s, and rubbed like crazy on one side until rolling fenders.
Old Oct 8, 2008 | 06:16 AM
CELTIC Z's Avatar
CELTIC Z
rolling fenders is not an option, maybe go with a lower profile tire, or maybe upgrade springs..... I have not had any rubbing anywhere else, why just the right rear??
Old Oct 8, 2008 | 06:26 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Im on 25mm in rear and never had a problem..
Old Oct 8, 2008 | 07:10 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The fact that you spaced the wheel out 30mm from where it was before is what caused it. The cars don't all come with the same alignment settings from the factory, and since tire sizes also vary (not all 275/40/18 are the same physical dimension for example), some cars will rub, others won't. It really is all the luck of the draw many times.
Your options that will absolutely work:
fit smaller spacers
roll the fenders
narrower tire
options that might work:
more negative camber (also affects toe, so do this carefully)
shorter height tire
lower springs - I put this in the "may" catergory, because while you will get a more negative rear camber, because they are lower, you may find yourself now hitting that rub limit more frequently
Old Oct 8, 2008 | 12:15 PM
CELTIC Z's Avatar
CELTIC Z
fit smaller spacers
roll the fenders
narrower tire
shorter height tire
thanks Z1, I think my best option will be to go with a smaller spacer 1st and then a smaller tire if needed.....thanks for the help
Old Oct 8, 2008 | 12:26 PM
THE_SCHROED's Avatar
THE_SCHROED
What are your offsets now? If your running low offsets your probably going to rub. Just go roll your fenders. It's easier and cheaper to do that than go buy 4 new tires.
Old Oct 9, 2008 | 06:55 AM
CELTIC Z's Avatar
CELTIC Z
offset are +38 at all 4 corners, I'm running 20mm spacers up front and 25mm rear, how hard is it to roll fenders?
Old Oct 9, 2008 | 07:29 AM
THE_SCHROED
If you know someone local with a fender roller they will probably do it for cheap, but a shop will usually charge like $200. It's not hard, all they do is heat it up and roll it with the machine. Not more than an hours work.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
