spc camber kit and stance gr+ coilover pics
Old Oct 14, 2008 | 08:04 PM
jaaf's Avatar
jaaf
Default spc camber kit and stance gr+ coilover pics
these pics could help for diy installations....
plus i jus wanted to show off my new setup... thnx to Z1 Performance and IntenseAero
SPC Rear Camber Kit
~new and old toe bolts
~many ppl think u have install the new toe bolts on the camber arm, but thats a negative!!
Stance Gr+ coilovers - oem progressive style rear- 12k/11k
~notice the rear damper **** extensions
~front damper adjust ****
~rear damper adjust **** w/extension
~needed to mess with the cover to fit the ****
Old Oct 14, 2008 | 09:09 PM
35oZephyR's Avatar
35oZephyR
Nice pics...those stance coilovers look like quality parts.
Old Oct 14, 2008 | 09:26 PM
SchismX's Avatar
SchismX
Though I don't have the same coilovers, I was going to ask if you reused the bottom rubber pieces that go on your rear springs?
Old Oct 15, 2008 | 07:34 AM
Threads's Avatar
I was going to ask what setting you have the lock nuts at for the rear spring seat. Mines are in the middle and my rear is really stiff...
Mine didnt come with the rear extensions for the dampening.
Old Oct 15, 2008 | 09:06 AM
gorillagoggles's Avatar
gorillagoggles
Wow very nice set-up. Haven't seen too many of these coilovers, but look like a very
solid product
Old Oct 15, 2008 | 10:16 AM
jaaf's Avatar
jaaf
yea i used the top and bottom rubber pieces...
~all the way at the top, lol...
~mine didnt come with them either, you can order the extensions from stance for about 50 bucks...
Old Oct 15, 2008 | 12:41 PM
Threads's Avatar
Assuming we have the same rate springs, how stiff is your ride in the back?? Because mine is really stiff on nice sized bumps. I have my dampening in the back turned all the way soft.
Old Oct 15, 2008 | 08:12 PM
got556's Avatar
got556
Nice pics...so where exactly did you put your toe bolts?
Also..I'm about ready to go back and put on my rear rubber pieces as I have the GR+ Pro's and they rattle w/out the rubber pieces on the spring.
I'm running full stiff in front and on 8 in the rears. Any pics of how low you went? I'm pretty much as low as "w/out rubbing" possible in the front and slammed in the rear but had to cut my rear lips.
One other tip...re-check/re-tighten your camber arm adjusters every now and then. I had my driver side loosen up on me awhile back and I drove about 200 miles before I really noticed it.
Once again...great pics but I wanna see some pics on how low you went also.
Old Oct 16, 2008 | 10:26 AM
jaaf's Avatar
jaaf
~i put the toe bolts on the inboard side of the spring bucket...check the pics it is circled...
~full stiff on all 4...
~here are pics of the car: https://my350z.com/forum/media-share...-out-ppls.html
~im gonna raise it about 1/4inch on all 4 sides, cuz its way too low...
Old Oct 13, 2009 | 01:48 PM
chad_z33's Avatar
chad_z33
me to.its really stiff over bumps.
in the picture, the spring adjustment is all the way at the bottom.how did that ride?
whats your setup now?does it clunk? thanks in advance
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
