Response from Koni
Old Aug 12, 2003 | 05:30 PM
jmark's Avatar
jmark
Default Response from Koni
FYI. I received this email response.
Mark,
The shocks are developed for the 350Z but we are waiting for the first production run to be built. They will take care of the bounce that you feel as they are valved to give the car great handling but still give a nice smooth ride. Thanks for writing.
Gordon
Old Aug 12, 2003 | 09:36 PM
Gsedan35's Avatar
Gsedan35
Yeah Gordon told me the same thing about a month ago on the phone. Were still on track for these coming out in the fall it looks like. But I didn't ask if their going to be single (rebound only) adjustable or double adjustable (rebound and compression). God I hope their double.
Old Aug 12, 2003 | 10:31 PM
zoasis's Avatar
zoasis
they're too late, I've already spent $2K with JIC!! :-)
Old Aug 13, 2003 | 05:59 AM
jmark's Avatar
jmark
Another reply:
Mark,
I don't have an exact release date on the shocks or a price at this time. The shocks will be externally adjustable for rebound damping. Thanks for writing.
Gordon
Old Aug 13, 2003 | 06:35 AM
jmark's Avatar
jmark
One last answer from Koni.
Mark,
>I assume the shocks will from the Street Sport Series.(Yellow) Is that correct?
Yes, they will be the Sport model. We will keep our dealers and customers as up to date as possible on the release of the 350Z application but I don't see it becoming available until late Fall. Thanks for writing.
Gordon
Old Aug 13, 2003 | 07:08 AM
2003z's Avatar
2003z
One of the nat'l level auto-x'ers and one lap competitors had some one-off adjustable konis on his Z at the last SCCA divisional and his car didnt lean at all in the turns. Of course they cost him something like $3000.
Old Aug 13, 2003 | 09:22 AM
Gsedan35's Avatar
Gsedan35
Thanks for letting me know their going to be single adjustable.
Well, that's not good new's for me, I'll have to consider the cost to send them back to be converted into double adjustable vs going another route to get the same adjustability.
Old Aug 13, 2003 | 10:40 AM
Audito350Z's Avatar
Audito350Z
if single-adjustable Konis don't do the trick... then you might need these:
http://www.motonsuspension.com/start.htm
Old Aug 13, 2003 | 01:03 PM
dwnshift's Avatar
dwnshift
We are the distributor for the Moton shock for the 350Z and did all the development with them.
We also have the Penskes coming next week. 1 ways or we can do 2 ways.
See the Penske shock post.
both of these shock sets can be purchased through
www.350EVO.com
Old Aug 14, 2003 | 03:35 AM
MannishBoy's Avatar
MannishBoy
That's Carter Thompson. He posts here on occasion.
Old Aug 14, 2003 | 03:40 AM
jmark's Avatar
jmark
What do you think the price for these Koni 1 way adjustable Yellow Sport shocks will be? I am hoping for the $500-600 range per set.
Old Aug 14, 2003 | 05:58 AM
tomsn16's Avatar
tomsn16
Default Ko
My guess is the Koni single adjust Yellows will be about $150/corner. Carter's custom doubles were about $600/corner.
The yellows should have less initial compression(won't be as bumpy as stock)and will have plenty of rebound adjustment.We run Carter's compression low and rarely change it making me think that the Yellows will be just as good as doubles for autoX.
Old Aug 14, 2003 | 06:40 AM
jmark's Avatar
jmark
Default Re: Ko
Can you explain what the problem is with the stock shocks? Most of us have the bounce.
Old Aug 14, 2003 | 08:06 AM
dwnshift's Avatar
dwnshift
Its not jsut the shocks.....dont get me worng they are part of the problem... The rear bushings have to much "wind-up" in them.
Anyone the is bored and has the time...
remove a rear shock........and push up on the upper control arm .then stand back and let it go.
There are other problems wiht the rear gemoetry as well.
Old Aug 14, 2003 | 08:12 AM
jmark's Avatar
jmark
I am looking for reasonably priced fix. I think at around $600 the Koni Sport is the way to go. What other suggestions do you have Dwnshift?
Old Aug 14, 2003 | 12:47 PM
2003z's Avatar
2003z
I know, just don't like to post other people's names.
Old Aug 14, 2003 | 01:40 PM
tomsn16's Avatar
tomsn16
Default Re: Re: Ko
JMARK....don't think there is anything really wrong with the stock shocks it's just that Nissan chose to build in rather high initial compression(bump) which gives a very firm feel to all the road bumps. On our custom doubles we have found the best compression adjustment to be well below the stock shocks for autox. Nice thing about the low compression is the car rides like a luxury sedan on the street in comparision to stock. I think the Koni Yellows will have a similarly low compression valving but I don't know that for sure.
The rebound settings we use with the custom units is just a little higher than the stock shocks but the custom units work far better. They reduce understeer,reduce inside rear wheel spin and have almost eliminated wheel hop on hard Pro Solo launches.Hope this helps.
Old Aug 14, 2003 | 03:00 PM
jmark's Avatar
jmark
Default Re: Re: Re: Ko
Thanks Carter! Sounds like the Koni's will be perfect for my needs. Can you recommend sway bars? Congrats on the One Lap finish and good luck at Topeka!
Old Aug 14, 2003 | 03:24 PM
MannishBoy's Avatar
MannishBoy
Well, he (and his partner) posted here himself about his one lap exploits, so I assumed it was OK. Sorry if it wasn't
Old Aug 14, 2003 | 03:55 PM
Boomer's Avatar
Boomer
What do you mean by 'WINDUP" and what happens when you remove a shock, push up on the upper control arm and let it go? Suspension technology is 50% science and 50% alchemy, like magic, to me. Please give me a baseline on what you are talking about. Thanks
