highest spring rate
Old Oct 20, 2008 | 02:57 PM
mw9's Avatar
mw9
Default highest spring rate
Does anyone know the springs with the highest rate. I am looking for around 500lb front and rear. Its looks like I would have to go to a coilover for those rates. Just curious if anyone made a set.
Old Oct 20, 2008 | 03:40 PM
Done Deal DR's Avatar
Done Deal DR
500lb? Thats hardly anything.
Old Oct 20, 2008 | 04:58 PM
redlude97's Avatar
redlude97
If you can find them still, the Nismo T2 springs have springrates of 625F/700R. Don't even think about running them with stock shocks though. Revalved koni yellows are probably your best bet
Old Oct 22, 2008 | 09:43 AM
Gsedan35's Avatar
Gsedan35
I know how, far bigger issue however relates to controlling the spring, I sent you a detailed pm on shock option's.
For Koni or Bilstein based shocks you can purchase 1/4" thick 6061 aluminum and make your own front spring seats, which is what I did. This will allow you to purchase Tein tapered springs in your choice of spring rate. This also avoids issues with what upper mount to use since the Tein tapered springs are sized to reuse the oem upper shock mount. For the rear, purchase one of those $109 ebay coilover kits. The rear adjustment system works well and the rear springs in the kit happen to be 500lbs in rate. Want to use a different rear rate with the kit? All you do is buy Eibach ESS springs 5" inside diameter and 9.5" in length. The only modification you do is to cut just enough of the end of the spring off so they will sit in the rear lower control arm.
Old Oct 22, 2008 | 01:34 PM
mw9's Avatar
mw9
thanks for the help. is this the ebay one
http://cgi.ebay.com/ebaymotors/03-04...mZ250312529247
EnjukuRacing
Sep 30, 2015 06:55 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
