camber kit Q
Old Dec 17, 2008 | 05:45 PM
ROM350Z's Avatar
ROM350Z
Default camber kit Q
Hi! Im on the verge of ordering eibach sportline springs for my 08 Z. I did some research and now i know for sure that ill be needing a camber kit. My main question is if ill be needing a camber kit for the front and back? Or only for the rear? Which is the most crucial and do most people do front and rear? Or can i just do the rear?
Old Dec 17, 2008 | 05:48 PM
BERTO's Avatar
BERTO
I have sportlines on my 06.
YES you need them for the rear.
some say optional for the front. My car happens to track right since lowered.
I recommend the front kit.
Old Dec 18, 2008 | 04:32 AM
Beau's Avatar
Beau
I'd say rear is required, front is optional.
It depends on your opinion of "acceptable" amounts of camber up front. I only lowered my car .5" in front and gained -.5 degrees of camber. So you will gain more putting you at -1.3+. If you want/need that much camber or MORE, then you probably don't need to worry about it. If you want/need LESS camber than that (better tire wear is basically the only advantage) then you will definitely need camber arms.
Old Dec 18, 2008 | 04:34 AM
JasonZ-YA's Avatar
JasonZ-YA
^^ Both great replies......
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
