Successful SPC A Arm Install w/Spacers?
Has anyone successfully installed the SPC A Arms with the supplied spacers? I have an approximate 2" drop (H&R spring for the 350z) and i know im going to be needing more than 1 degree of adjustment. From what i understand, the SPC A arms alone allow 1 degree of adjustment and w/the spacers installed, there is another 2 degrees of adjustment?Im currently running the Cusco A Arms, set to max adjustment, and i am just out of specs. I have 2 friends that are running the SPC A arms, and they have had a lot of problems with getting rid of the VDC + ABS lights (even after adjusting the supplied ABS bracket). I had unfortunately purchased the SPC A Arms last week w/o knowing of this inherent issue.
So again, my question is Has anyone successfully installed the SPC A Arms with the supplied spacers?
And has anyone got a successful alignment w/SPC a arms w/the supplied spacers installed in SoCal? Id like to find an alignment shop in socal that has experience w/these arms
SPC part #72125
SPC part #72125
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
