eiback prokit VS tanabe GF210
Old Mar 4, 2009 | 07:37 AM
moforeynolds's Avatar
moforeynolds
Originally Posted by TheOtherRob
Doesn't the NF210 and sportlines create the same drop? 1.2 all around
not even close. The NF210s are about the same as the ProKits, regardless of eithers' advertised drop; the Sportlines outright slam the car. For comparision, this is mine on Sportlines:
More pictures are in my Gallery.
I love the look, but for whoever above that said the ride quality "remained the same" is full of chit The ride is harsh, regardless of the dampers you run--ESPECIALLY the first 500 or so miles during break-in. After that, I would compare the ride to your standard coil-over (two friends are on stance and jic).
Old Mar 4, 2009 | 08:17 AM
Ricfutures's Avatar
Ricfutures
I have the Sportkit and they slam the car. You will scrape if you have any large speed bumps or steep driveways. I have become a pro at angling.
I have always used Eibach springs so I would recommend them over most brands but call me bias.
Whatever you do make sure you get yourself some aftermarket shocks with the springs or will end up paying 2x for labor in the long run. I have the Tockico D Specs and love them with these springs.
Best of luck.
Old Mar 4, 2009 | 08:43 AM
WalkerT's Avatar
WalkerT
Professional
I used the prokit on my 05 and now on my 07 and I love the drop and ride. There is a tone of pics in my album
https://my350z.com/forum/members/wal...s-walkert.html
Old Mar 4, 2009 | 09:33 AM
Stogge's Avatar
Stogge
I got out the measuring tape for you today... With GF210's, my rear end (at the center of the back wheel well) is 1" higher in the rear...
Old Mar 4, 2009 | 02:38 PM
tw8715's Avatar
tw8715
wow thanks guys! really good help!
well seems like both the kits.. the rear is higher.
just what i wanted!
so i guess its all about pricing then! but deng i really like the pics of the eibach drop on that red Z of yours!
thanks for the help guys!
Old Mar 4, 2009 | 02:41 PM
tw8715's Avatar
tw8715
hey stogge! would you happen to have pics of your car as well?
and also walkerT are all the photos in your album have the drop with the eibachs?
thanks!
Old Mar 4, 2009 | 03:09 PM
quakerroatmeal's Avatar
quakerroatmeal
The NF210 is more of an even all around. The rear is BARELY a little higher.
Old Mar 4, 2009 | 07:18 PM
tw8715's Avatar
tw8715
there we go! my answer found! haha
thanks!
tanabe it is!
Old Mar 6, 2009 | 04:07 AM
WalkerT's Avatar
WalkerT
Professional
thanks!
Yes they are all dropped on the prokit. The SS is my old 05.
Old Mar 6, 2009 | 01:40 PM
Stogge's Avatar
Stogge
Tanabe makin my ride soooooo Purrrty... Wheels I ordered in December, STILL AREN'T HERE... GF210's vvv
Old Mar 6, 2009 | 01:42 PM
Stogge's Avatar
Stogge
How is that Lip working out for you with the drop? I want the same, but is it a PITA?
Old Mar 7, 2009 | 01:33 PM
quakerroatmeal
Lip is fine, its not low. Your GF210 looks low. Maybe cause the wheels are all tucked inside the fender.
Old Mar 9, 2009 | 01:09 PM
XTMACX's Avatar
XTMACX
So with either one of these kits I'm gonna need a rear camber kit? Or at least its highly recommended? I'd rather get a camber kit for $150 instead of replacing rear tires every 10,000 miles. Which camber kit would you guys recommend? I'll be installing this on my '04 350z with the 19" Volk GT-V's I'll be getting next week (9.5 and 10.5). And I'm just assuming put them on the stock shocks since I'm not gonna be tracking it or anything.
Old Mar 9, 2009 | 01:17 PM
Spork's Avatar
Spork
SPC rear camber arms.
I'm going with those when I get my NF210's.
Old Mar 14, 2009 | 11:57 PM
danimaldaisy's Avatar
danimaldaisy
seems that you guys are just going for the drop...
i had the GF 210's on for a week with BRAND NEW tokico blues.
the ride was too soft and felt horrible. The specs prove my point....they are in my garage and will be going into the trash on wednesday....
dont see how these or the prokit are anygood, unless you buy the d-spec and max out the valving....but shouldnt a good spring not require this???
Old Mar 14, 2009 | 11:58 PM
danimaldaisy
by the way all the springs mentioned in this thread are progressive.
the stock springs are linear
Old Mar 20, 2009 | 06:30 PM
chrisjersey06's Avatar
chrisjersey06
So far the only springs I can see that you'd be able to keep stock shocks and not need a camber kit for are the Pro-Kits. Any others? GF210's? S-Tech's? I know with a more aggressive spring like the Sportlines you'd definitely need both.
Old Mar 20, 2009 | 08:44 PM
  #38
TheOtherRob's Avatar
TheOtherRob
^ It is recommended to change the stock shocks/struts with any lowering spring. But, you may last longer with the cobb's or the tien s techs. The pro kit from what ive seen, lowers the car just as low as the tanabes. About a finger gap front and rear.
Old Mar 21, 2009 | 04:34 AM
  #39
adamh's Avatar
adamh
This is my car with GF210's on 19's.
Old Mar 21, 2009 | 08:23 AM
  #40
enlite's Avatar
enlite
if you install lowering springs with stock shocks, and one of the stock shocks blows, isn't the car going to be scraping the ground?
