What are the stiffest springs I can get for the 350z?
Old Mar 21, 2009 | 10:35 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by JohnnyHT
Re: the T2's...NISMO "claims" they can be used with the stock shocks...any truth to this statement? (albiet ANY spring can be used with stocks but it's only a matter of time before failure)
They (Nissan Motorsports) know you cannot run the springs with oem shocks. The point they are trying to get across is that the springs are class legal because they use the same oem spring seats or mounts. As your post show's they made a poor choice of words.
Old Mar 22, 2009 | 10:54 AM
JohnnyHT's Avatar
JohnnyHT
Beating the dead horse...again (lol)
What shocks WOULD you recommend for the stock shocks (performance-wise)? I could care less about looks and wheel gap. Every spring thread I'm finding is "s1cK m4d tyt3 dr0p l00kz g00d, y0"...
Still lurking though...maybe I'll find SOMETHING. :P
Old Mar 23, 2009 | 09:15 AM
Gsedan35's Avatar
Gsedan35
Koni yellows
All 4 can be revalved for $500 if you end up feeling the need to.
If you do not have to have adjustablity and you'd like more comfort
Bilstein HD
All 4 can be revalved by Bilstein NA for $260, again if you end up feeling the need to.
Old Mar 24, 2009 | 10:13 PM
Shift__Z's Avatar
Shift__Z
Im in a similar situation, Im looking for a good track shock/spring combo. Ill probably be going with konis as well. I just need to figure out which springs.
Old Mar 30, 2009 | 04:07 PM
mw9's Avatar
mw9
As, always good info Gsedan35
Old Apr 1, 2009 | 08:16 AM
mw9's Avatar
mw9
Do not use progressive springs on a car intented for the track,......period. I will front and center not recommend them for a car you'll drive anyplace aggressively either. For your intended purpose, for what you want to do it is a compromise that fly's in the face of what you want and cost you the very things your trying to accomplish in modifying the suspension.
If you want 392lbs front and 448lbs rear, you can do it just like I did, only thing you'll need to add to have a 1.2" drop in the front is to spend a few dollars with Koni shop services. You would have them do a simple mod to the front Koni shocks, have them cut out a 5/8" section from the lower leg of the shock just above the lower mount and reweld.
OTS Koni yellows $800 new or $400 used
Tein tapered springs 392lbs $120
6061 machined lower spring seats (front) $25 and your time
Tom's Motorsports adjustable rear spring seats $160
Eibach or hypercoil 5.5" outside diameter springs 9.5" tall 448lbs $125
What size spring for the front? Thanks
Old Apr 18, 2009 | 01:30 PM
Peak350's Avatar
Peak350
Rather than make a new thread, I'm looking to take a little jostle out of the front of the car without stiffening the sway bar much.
Car will be seeing auto-x and eventually HDPE/TT use.
Current setup in mind:
Cusco or similar upper A-Arms
Koni Yellows (OTS)
Tein S-Tech springs (386F/402R)
Eibach (or similar) rear camber arms + toe bolts
Probably will play with sways in the future, but my biggest complaint is poor turn in under braking (I know camber plays a large role here) and the shocks just being a bit soft factory. I think -2 camber front, transfer of spring stiffness to front, and shock adjustability will really help here.
As a side note, would it be worthwhile to consider D-spec shocks over Koni's?
Thoughts? (GSedan35 especially).
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
