Z33 with Z32 calipers....
Old Mar 19, 2009 | 06:19 AM
0jiggy0's Avatar
0jiggy0
did you do a before brake test. id bet the braking ability suffered
Old Mar 19, 2009 | 06:41 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yep. This is why many Z32 owners upgrade to Z33 brakes due to poor braking. So basically you downgraded your brakes sir. The Z33 one piston or two piston can out perform the Z32 brakes without a problem.
Old Mar 19, 2009 | 01:30 PM
DavesZ#3's Avatar
DavesZ#3
It will be pointless unless he goes out and runs some actual tests of stopping distance, temperature, etc.
Old Mar 19, 2009 | 03:46 PM
Chebosto's Avatar
Chebosto
only benefit i see is cheaper race pads, lighter unsprung weight, and running 17" rims with race tires??
i thought people just buy G37 calipers or OE Brembos and call it a day?
Old Mar 19, 2009 | 05:39 PM
oro's Avatar
oro
Yeah I would assume the better "cheap" option would be going with the G37/370 brakes, if my memory serves me correctly they are a bit bigger and have 4 pistons already.
Old Mar 19, 2009 | 06:02 PM
Z33_kid's Avatar
Z33_kid
a waste... get g37s
Old Mar 19, 2009 | 06:08 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by Z33_kid
a waste... get g37s
Agreed
https://my350z.com/forum/brakes/4142...at-1200-a.html
Old Mar 19, 2009 | 10:56 PM
SoldzMyZ's Avatar
SoldzMyZ
It looks odd for some reason.
Old Mar 19, 2009 | 11:51 PM
Maresh@Blackline's Avatar
Maresh@Blackline
Vendor - Former Vendor
i applaud your work so far but.....
Originally Posted by Geox1
sure thats what you think.... just on the upgrade of the master cylinder from a non brembo to a brembo. even just the master cylinder makes a lot of difference the bigger master cylinder more fluid gets pump.....
....the brembo master cylinder from a 350z to a non-brembo 350z MC is...wait never mind they're the exact same, there is no difference, the exact same part
Old Mar 20, 2009 | 03:14 AM
DavesZ#3's Avatar
DavesZ#3
While the MC is the same, the booster is different. Some people doing the upgrade swap the whole assembly (MC and booster), others don't bother. I haven't noticed any difference in brake performance with the non-Brembo booster and Brembo brakes.
Old Mar 20, 2009 | 05:27 AM
Z04's Avatar
Z04
Alright ladies and gents i know there is already a thread to this topic already about putting z32 brake calipers on a z33.... its a good up grade from the stock one piston calipers to four pod calipers.... Ill keep u posted on this, if u want to share any info. let me know... Im still working on my convertion.... I did it but there is lil issues i need to fix.... and trust me those calipers work better than the stock calipers....
then why start another thread about it then? also if they was so good, why didn't Nissan, with all of their design and research teams, put those brakes onto the 350Z then?
Old Mar 20, 2009 | 10:21 AM
Jeff92se's Avatar
Jeff92se
Which rotors? The oem Z32 11.5"? Or the oem Z 11.5" rotors? If yes, then it's not much of an upgrade. Pedal feel might be improved or maybe a slight amount of brake force might be increased but most likely not by much. Larger rotors net you bigger differences in torque applied to stopping than what the Z32 calipers would net you.
Old Oct 9, 2009 | 10:05 PM
joe645733's Avatar
joe645733
shouldve gotten the skyline upgraded rotors...theyre pretty cheap. most z32tt owners have em'. drilled and slotted too.
sales@czp
Sep 23, 2019 03:30 PM
jlc280z
Sep 24, 2015 08:43 AM
